[postgis-tickets] [PostGIS] #5490: Upgrade from 3.1.1: ERROR: cannot drop function st_slope(raster, integer, text, text, double precision, boolean) because other objects depend on it
PostGIS trac at osgeo.org
Mon Aug 28 14:20:05 PDT 2023
st_slope(raster,integer,text,text,double precision,boolean) because other
 Reporter:  strk                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  medium                 |  Milestone:  PostGIS 3.4.1
Component:  build/upgrade/install  |    Version:  3.4.x
 Keywords:  raster                 |
 Another case of upgrade trouble:
 =# select postgis_extensions_upgrade();
 NOTICE:  Updating extension postgis from 3.1.1 to 3.4.0
 NOTICE:  Extension postgis_sfcgal is not available or not packagable for
 some reason
 ERROR:  cannot drop function st_slope(raster,integer,text,text,double
 precision,boolean) because other objects depend on it
 See also #5488
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5490>
