[postgis-tickets] [PostGIS] #5489: Upgrade from 3.1.1: ERROR: cannot drop function st_intersects(raster, geometry, integer) because other objects depend on it
PostGIS trac at osgeo.org
Mon Aug 28 14:44:12 PDT 2023
st_intersects(raster,geometry,integer) because other objects depend on it
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 3.4.1
 Component:  build/upgrade/install  |    Version:  3.4.x
Resolution:  fixed                  |   Keywords:
Changes (by Sandro Santilli <strk@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"df07c2995551ca80157333a9b366261871476f82/git" df07c29/git]:
 {{{#!CommitTicketReference repository="git"
 revision="df07c2995551ca80157333a9b366261871476f82"
 Fix upgrades in presence of views using st_intersects(..raster..)
 Includes regress tests
 Closes #5489 in 3.4 branch (3.4.1dev)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5489#comment:6>
