[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-63-g99ddb20a4
Mon Aug 28 14:41:46 PDT 2023
the project "PostGIS".
       via  99ddb20a49b739c4f6d566d14359b3f8dfa5fd42 (commit)
      from  e1b7db45486fea9cb3c0be8d58cbd2a785b631f4 (commit)
revisions in full, below.
commit 99ddb20a49b739c4f6d566d14359b3f8dfa5fd42
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Aug 28 22:40:35 2023 +0200
    Fix upgrades in presence of views using st_intersects(..raster..)
    Includes regress tests
    References #5489 in master branch (3.5.0dev)
diff --git a/raster/rt_pg/rtpostgis_drop.sql.in b/raster/rt_pg/rtpostgis_drop.sql.in
index 5f4a8f9aa..ef6a57ada 100644
--- a/raster/rt_pg/rtpostgis_drop.sql.in
+++ b/raster/rt_pg/rtpostgis_drop.sql.in
@@ -48,12 +48,21 @@ DROP AGGREGATE IF EXISTS ST_Union(raster, text, text);
 DROP AGGREGATE IF EXISTS ST_Union(raster, text, text, text, double precision);
 DROP AGGREGATE IF EXISTS ST_Union(raster, record[]);
+-- Removed in 2.0.0 ? see ticket #5489
 DROP FUNCTION IF EXISTS ST_Intersects(raster,boolean,geometry);
 DROP FUNCTION IF EXISTS ST_Intersects(geometry,raster,boolean);
 DROP FUNCTION IF EXISTS ST_Intersects(raster,geometry);
 DROP FUNCTION IF EXISTS ST_Intersects(geometry,raster);
 DROP FUNCTION IF EXISTS ST_Intersects(raster, integer, boolean, geometry);
 DROP FUNCTION IF EXISTS ST_Intersects(geometry, raster, integer, boolean);
+-- Removed in 2.1.0, see ticket #5489
+DROP FUNCTION IF EXISTS _st_intersects(raster, geometry, integer);
 DROP FUNCTION IF EXISTS ST_Intersection(raster,raster, integer, integer);
 DROP FUNCTION IF EXISTS ST_Intersection(geometry,raster);
diff --git a/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in b/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in
index bed083b66..fcde527e2 100644
--- a/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in
+++ b/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in
@@ -433,9 +433,15 @@ CREATE OR REPLACE FUNCTION _drop_st_samealignment()
 SELECT _drop_st_samealignment();
 DROP FUNCTION _drop_st_samealignment();
-DROP FUNCTION IF EXISTS _st_intersects(raster, integer, raster, integer);
-DROP FUNCTION IF EXISTS st_intersects(raster, integer, raster, integer);
-DROP FUNCTION IF EXISTS st_intersects(raster, raster);
+--DROP FUNCTION IF EXISTS _st_intersects(geometry, raster, integer); --------- sig1, not changed since 2.0.0, see ticket #5489
+--DROP FUNCTION IF EXISTS _st_intersects(raster, integer, raster, integer); -- sig2, not changed since 2.0.0, see ticket #5489
+--DROP FUNCTION IF EXISTS st_intersects(raster, integer, raster, integer); -- sig1, not changed since 2.0.0, see ticket #5489
+--DROP FUNCTION IF EXISTS st_intersects(raster, raster); -------------------- sig2, not changed since 2.0.0, see ticket #5489
+--DROP FUNCTION IF EXISTS st_intersects(geometry, raster, integer); --------- sig3, not changed since 2.0.0, see ticket #5489
+--DROP FUNCTION IF EXISTS st_intersects(raster, geometry, integer); --------- sig4, not changed since 2.0.0, see ticket #5489
+--DROP FUNCTION IF EXISTS st_intersects(raster, integer, geometry); --------- sig5, not changed since 2.0.0, see ticket #5489
 -- functions have changed dramatically
 DROP FUNCTION IF EXISTS st_intersection(raster, integer, geometry);
@@ -452,9 +458,9 @@ DROP FUNCTION IF EXISTS st_intersection(raster, int, geometry, text, regprocedur
 DROP FUNCTION IF EXISTS st_intersection(raster, int, geometry, regprocedure);
 DROP FUNCTION IF EXISTS st_intersection(raster, geometry, text, regprocedure);
 DROP FUNCTION IF EXISTS st_intersection(raster, geometry, regprocedure);
---DROP FUNCTION IF EXISTS st_clip(raster, geometry, float8, boolean); --------- sig5, not changed since 2.0.0, maybe changed before ?
---DROP FUNCTION IF EXISTS st_clip(raster, geometry, boolean); ----------------- sig6, not changed since 2.0.0, maybe changed before ?
---DROP FUNCTION IF EXISTS st_clip(raster, geometry, float8[], boolean); ------- sig4, not changed since 2.0.0, maybe changed before ?
+--DROP FUNCTION IF EXISTS st_clip(raster, geometry, float8, boolean); --------- sig5, not changed since 2.0.0, see ticket #5488
+--DROP FUNCTION IF EXISTS st_clip(raster, geometry, boolean); ----------------- sig6, not changed since 2.0.0, see ticket #5488
+--DROP FUNCTION IF EXISTS st_clip(raster, geometry, float8[], boolean); ------- sig4, not changed since 2.0.0, see ticket #5488
 -- refactoring of functions
 DROP FUNCTION IF EXISTS _st_dumpaswktpolygons(raster, integer);
@@ -480,13 +486,6 @@ DROP FUNCTION IF EXISTS st_pixelaspolygons(raster, integer);
 -- function deprecated
 DROP FUNCTION IF EXISTS st_bandsurface(raster, integer);
--- function no longer exist or refactored
-DROP FUNCTION IF EXISTS _st_intersects(raster, geometry, integer);
 -- function no longer exists
 DROP FUNCTION IF EXISTS st_overlaps(geometry, raster, integer);
 DROP FUNCTION IF EXISTS st_overlaps(raster, integer, geometry);
diff --git a/raster/test/regress/hooks/hook-after-upgrade-raster.sql b/raster/test/regress/hooks/hook-after-upgrade-raster.sql
index b044120f7..bb94684ae 100644
--- a/raster/test/regress/hooks/hook-after-upgrade-raster.sql
+++ b/raster/test/regress/hooks/hook-after-upgrade-raster.sql
@@ -1,10 +1,9 @@
 DROP VIEW upgrade_test_raster_view_st_value;
 DROP VIEW upgrade_test_raster_view_st_clip;
+DROP VIEW upgrade_test_raster_view_st_intersects;
 DROP TABLE upgrade_test_raster;
 DROP TABLE upgrade_test_raster_with_regular_blocking;
 -- Drop functions deprecated on upgrade
 DROP FUNCTION IF EXISTS st_value_deprecated_by_postgis_201(raster,geometry,boolean);
---DROP FUNCTION IF EXISTS st_value_deprecated_by_postgis_201(raster,geometry,boolean);
diff --git a/raster/test/regress/hooks/hook-before-upgrade-raster.sql b/raster/test/regress/hooks/hook-before-upgrade-raster.sql
index c445200c8..305bd7d05 100644
--- a/raster/test/regress/hooks/hook-before-upgrade-raster.sql
+++ b/raster/test/regress/hooks/hook-before-upgrade-raster.sql
@@ -40,7 +40,6 @@ SELECT
 FROM upgrade_test_raster;
 -- See https://trac.osgeo.org/postgis/ticket/5488
--- st_clip(raster,integer,geometry,double precision,boolean)
 CREATE VIEW upgrade_test_raster_view_st_clip AS
 SELECT
 	-- signature dropped in PostGIS-2.1.0
@@ -52,3 +51,12 @@ SELECT
 	st_clip(NULL::raster, NULL::geometry, NULL::float8[], NULL::boolean) sig4,
 	st_clip(NULL::raster, NULL::geometry, NULL::float8, NULL::boolean) sig5,
 	st_clip(NULL::raster, NULL::geometry, NULL::boolean) sig6;
+-- See https://trac.osgeo.org/postgis/ticket/5489
+CREATE VIEW upgrade_test_raster_view_st_intersects AS
+SELECT
+	st_intersects(NULL::raster, NULL::int, NULL::raster, NULL::integer) sig1,
+	st_intersects(NULL::raster, NULL::raster) sig2,
+	st_intersects(NULL::geometry, NULL::raster, NULL::int) sig3,
+	st_intersects(NULL::raster, NULL::geometry, NULL::int) sig4,
+	st_intersects(NULL::raster, NULL::int, NULL::geometry)  sig5;
Summary of changes:
 raster/rt_pg/rtpostgis_drop.sql.in                 |  9 ++++++++
 raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in      | 25 +++++++++++-----------
 .../regress/hooks/hook-after-upgrade-raster.sql    |  3 +--
 .../regress/hooks/hook-before-upgrade-raster.sql   | 10 ++++++++-
 4 files changed, 31 insertions(+), 16 deletions(-)
hooks/post-receive
