[postgis-tickets] [PostGIS] #5490: Upgrade from 3.1.1: ERROR: cannot drop function st_slope(raster, integer, text, text, double precision, boolean) because other objects depend on it
PostGIS trac at osgeo.org
Tue Aug 29 02:00:14 PDT 2023
st_slope(raster,integer,text,text,double precision,boolean) because other
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 3.4.1
 Component:  build/upgrade/install  |    Version:  3.4.x
Resolution:  fixed                  |   Keywords:  raster
Changes (by Sandro Santilli <strk@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"c1f65ad8768deb96353cf4fe26dab85241ba3e49/git" c1f65ad/git]:
 {{{#!CommitTicketReference repository="git"
 revision="c1f65ad8768deb96353cf4fe26dab85241ba3e49"
 Fix upgrades in presence of views using st_slope(..raster..)
 Adds availability info to the function signatures
 Closes #5490 in 3.4 branch (3.4.1dev)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5490#comment:5>
