[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-65-g197a187f2
Tue Aug 29 03:01:14 PDT 2023
the project "PostGIS".
       via  197a187f242466aa579b052b0afa553ff42fb7d7 (commit)
      from  3ecd48c7fa8c97142e00fd4e5467ca22223a0f93 (commit)
revisions in full, below.
commit 197a187f242466aa579b052b0afa553ff42fb7d7
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Aug 28 23:58:16 2023 +0200
    Fix upgrades in presence of views using st_aspect(..raster..)
    Adds functions availability info
    References #5491 in master branch (3.5.0dev)
diff --git a/raster/rt_pg/rtpostgis.sql.in b/raster/rt_pg/rtpostgis.sql.in
index e30389607..ccb2863eb 100644
--- a/raster/rt_pg/rtpostgis.sql.in
+++ b/raster/rt_pg/rtpostgis.sql.in
@@ -3549,6 +3549,7 @@ CREATE OR REPLACE FUNCTION st_slope(
 -- http://webhelp.esri.com/arcgisdesktop/9.3/index.cfm?TopicName=How%20Hillshade%20works
+-- Availability: 2.1.0
 CREATE OR REPLACE FUNCTION _st_aspect4ma(value double precision[][][], pos integer[][], VARIADIC userargs text[] DEFAULT NULL)
 	RETURNS double precision
 	AS $$
@@ -3658,10 +3659,13 @@ CREATE OR REPLACE FUNCTION _st_aspect4ma(value double precision[][][], pos integ
 	END;
 	$$ LANGUAGE 'plpgsql' IMMUTABLE PARALLEL SAFE;
 CREATE OR REPLACE FUNCTION st_aspect(
-	rast raster, nband integer,
+	rast raster,
+	nband integer,
 	customextent raster,
-	pixeltype text DEFAULT '32BF', units text DEFAULT 'DEGREES',
+	pixeltype text DEFAULT '32BF',
+	units text DEFAULT 'DEGREES',
 	interpolate_nodata boolean DEFAULT FALSE
 	RETURNS raster
@@ -3713,9 +3717,14 @@ CREATE OR REPLACE FUNCTION st_aspect(
 	END;
+-- Availability: 2.0.0
+-- Changed: 2.1.0 changed nband parameter name, added units, interpolate_nodata and defaults
+-- Replaces st_aspect(raster, integer, text) deprecated in 2.1.0
-	rast raster, nband integer DEFAULT 1,
+	rast raster,
+	nband integer DEFAULT 1,
 	RETURNS raster
diff --git a/raster/rt_pg/rtpostgis_drop.sql.in b/raster/rt_pg/rtpostgis_drop.sql.in
index 72c4e085d..ad5cdf537 100644
--- a/raster/rt_pg/rtpostgis_drop.sql.in
+++ b/raster/rt_pg/rtpostgis_drop.sql.in
@@ -68,6 +68,11 @@ DROP FUNCTION IF EXISTS _st_slope4ma(float8[], text, text[]);
 -- Removed in 2.0.0 ? see ticket #5490
 DROP FUNCTION IF EXISTS st_slope(raster, integer, text, boolean);
+-- Removed in 2.1.0, see ticket #5491
+DROP FUNCTION IF EXISTS _st_aspect4ma(float8[], text, text[]);
+-- Removed before 2.0.0 ? see ticket #5491
+DROP FUNCTION IF EXISTS st_aspect(raster, integer, text, boolean);
 DROP FUNCTION IF EXISTS ST_Intersection(raster,raster, integer, integer);
 DROP FUNCTION IF EXISTS ST_Intersection(geometry,raster);
diff --git a/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in b/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in
index d08f34b59..0b32f5b13 100644
--- a/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in
+++ b/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in
@@ -511,9 +511,7 @@ DROP FUNCTION IF EXISTS _st_contains(geometry, raster, integer);
 DROP FUNCTION IF EXISTS st_addband(raster, raster[], integer);
 -- function signatures changed
-DROP FUNCTION IF EXISTS st_aspect(raster, integer, text, text, boolean);
-DROP FUNCTION IF EXISTS st_aspect(raster, integer, text, boolean);
-DROP FUNCTION IF EXISTS st_aspect(raster, integer, text);
+--DROP FUNCTION IF EXISTS st_aspect(raster, integer, text, text, boolean); --- sig2, not changed since 2.1.0, see ticket #5491
 DROP FUNCTION IF EXISTS st_hillshade(raster, integer, text, double precision, double precision, double precision, double precision, boolean);
 DROP FUNCTION IF EXISTS st_hillshade(raster, integer, text, float, float, float, float, boolean);
 DROP FUNCTION IF EXISTS st_hillshade(raster, integer, text, float, float, float, float);
@@ -562,7 +560,6 @@ DROP FUNCTION IF EXISTS _add_raster_constraint_regular_blocking(name, name, name
 -- function signature changed
 DROP FUNCTION IF EXISTS st_asbinary(raster);
-DROP FUNCTION IF EXISTS _st_aspect4ma(float8[], text, text[]);
 DROP FUNCTION IF EXISTS _st_hillshade4ma(float8[], text, text[]);
diff --git a/raster/test/regress/hooks/hook-after-upgrade-raster.sql b/raster/test/regress/hooks/hook-after-upgrade-raster.sql
index 950bf3631..59f57a7cc 100644
--- a/raster/test/regress/hooks/hook-after-upgrade-raster.sql
+++ b/raster/test/regress/hooks/hook-after-upgrade-raster.sql
@@ -6,6 +6,7 @@ DROP TABLE upgrade_test_raster;
 DROP TABLE upgrade_test_raster_with_regular_blocking;
 DROP VIEW upgrade_test_raster_view_st_slope;
+DROP VIEW upgrade_test_raster_view_st_aspect;
 -- Drop functions deprecated on upgrade
 DROP FUNCTION IF EXISTS st_value_deprecated_by_postgis_201(raster,geometry,boolean);
diff --git a/raster/test/regress/hooks/hook-before-upgrade-raster.sql b/raster/test/regress/hooks/hook-before-upgrade-raster.sql
index 92d64879b..58a6a1bc6 100644
--- a/raster/test/regress/hooks/hook-before-upgrade-raster.sql
+++ b/raster/test/regress/hooks/hook-before-upgrade-raster.sql
@@ -66,3 +66,9 @@ CREATE VIEW upgrade_test_raster_view_st_slope AS
 SELECT
 	st_slope(NULL::raster, NULL::int, NULL::raster) sig1,
 	st_slope(NULL::raster, NULL::int) sig2;
+-- See https://trac.osgeo.org/postgis/ticket/5491
+CREATE VIEW upgrade_test_raster_view_st_aspect AS
+SELECT
+	st_aspect(NULL::raster, NULL::int, NULL::raster) sig1,
+	st_aspect(NULL::raster) sig2;
Summary of changes:
 raster/rt_pg/rtpostgis.sql.in                           | 17 +++++++++++++----
 raster/rt_pg/rtpostgis_drop.sql.in                      |  5 +++++
 raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in           |  5 +----
 raster/test/regress/hooks/hook-after-upgrade-raster.sql |  1 +
 .../test/regress/hooks/hook-before-upgrade-raster.sql   |  6 ++++++
 5 files changed, 26 insertions(+), 8 deletions(-)
hooks/post-receive
