[postgis-tickets] [SCM] PostGIS branch stable-3.4 updated. 3.4.0-8-g2bf50fa5f
git at osgeo.org
git at osgeo.org
Tue Aug 29 03:02:13 PDT 2023
the project "PostGIS".
The branch, stable-3.4 has been updated
via 2bf50fa5fc6527d5597077937a3d77e6721b54aa (commit)
from c1f65ad8768deb96353cf4fe26dab85241ba3e49 (commit)
revisions in full, below.
commit 2bf50fa5fc6527d5597077937a3d77e6721b54aa
Author: Sandro Santilli <strk at kbt.io>
Date: Mon Aug 28 23:58:16 2023 +0200
Fix upgrades in presence of views using st_aspect(..raster..)
Adds functions availability info
Closes #5491 in 3.4 branch (3.4.1dev)
diff --git a/NEWS b/NEWS
index 5f81aaf6c..b1b365d99 100644
--- a/NEWS
+++ b/NEWS
@@ -6,6 +6,8 @@ To take advantage of all SFCGAL featurs, SFCGAL 1.4.1+ is needed.
* Bug Fixes *
+ - #5491, Fix upgrade with view using st_aspect(raster, ...)
+ (Sandro Santilli)
- #5490, Fix upgrade with view using st_slope(raster, ...)
(Sandro Santilli)
- #5489, Fix upgrade with view using st_intersects(raster, ...)
diff --git a/raster/rt_pg/rtpostgis.sql.in b/raster/rt_pg/rtpostgis.sql.in
index e30389607..ccb2863eb 100644
--- a/raster/rt_pg/rtpostgis.sql.in
+++ b/raster/rt_pg/rtpostgis.sql.in
@@ -3549,6 +3549,7 @@ CREATE OR REPLACE FUNCTION st_slope(
-- http://webhelp.esri.com/arcgisdesktop/9.3/index.cfm?TopicName=How%20Hillshade%20works
+-- Availability: 2.1.0
CREATE OR REPLACE FUNCTION _st_aspect4ma(value double precision[][][], pos integer[][], VARIADIC userargs text[] DEFAULT NULL)
RETURNS double precision
AS $$
@@ -3658,10 +3659,13 @@ CREATE OR REPLACE FUNCTION _st_aspect4ma(value double precision[][][], pos integ
END;
$$ LANGUAGE 'plpgsql' IMMUTABLE PARALLEL SAFE;
CREATE OR REPLACE FUNCTION st_aspect(
- rast raster, nband integer,
+ rast raster,
+ nband integer,
customextent raster,
- pixeltype text DEFAULT '32BF', units text DEFAULT 'DEGREES',
+ pixeltype text DEFAULT '32BF',
+ units text DEFAULT 'DEGREES',
interpolate_nodata boolean DEFAULT FALSE
RETURNS raster
@@ -3713,9 +3717,14 @@ CREATE OR REPLACE FUNCTION st_aspect(
END;
+-- Availability: 2.0.0
+-- Changed: 2.1.0 changed nband parameter name, added units, interpolate_nodata and defaults
+-- Replaces st_aspect(raster, integer, text) deprecated in 2.1.0
- rast raster, nband integer DEFAULT 1,
+ rast raster,
+ nband integer DEFAULT 1,
RETURNS raster
diff --git a/raster/rt_pg/rtpostgis_drop.sql.in b/raster/rt_pg/rtpostgis_drop.sql.in
index 72c4e085d..ad5cdf537 100644
--- a/raster/rt_pg/rtpostgis_drop.sql.in
+++ b/raster/rt_pg/rtpostgis_drop.sql.in
@@ -68,6 +68,11 @@ DROP FUNCTION IF EXISTS _st_slope4ma(float8[], text, text[]);
-- Removed in 2.0.0 ? see ticket #5490
DROP FUNCTION IF EXISTS st_slope(raster, integer, text, boolean);
+-- Removed in 2.1.0, see ticket #5491
+DROP FUNCTION IF EXISTS _st_aspect4ma(float8[], text, text[]);
+-- Removed before 2.0.0 ? see ticket #5491
+DROP FUNCTION IF EXISTS st_aspect(raster, integer, text, boolean);
DROP FUNCTION IF EXISTS ST_Intersection(raster,raster, integer, integer);
DROP FUNCTION IF EXISTS ST_Intersection(geometry,raster);
diff --git a/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in b/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in
index d08f34b59..0b32f5b13 100644
--- a/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in
+++ b/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in
@@ -511,9 +511,7 @@ DROP FUNCTION IF EXISTS _st_contains(geometry, raster, integer);
DROP FUNCTION IF EXISTS st_addband(raster, raster[], integer);
-- function signatures changed
-DROP FUNCTION IF EXISTS st_aspect(raster, integer, text, text, boolean);
-DROP FUNCTION IF EXISTS st_aspect(raster, integer, text, boolean);
-DROP FUNCTION IF EXISTS st_aspect(raster, integer, text);
+--DROP FUNCTION IF EXISTS st_aspect(raster, integer, text, text, boolean); --- sig2, not changed since 2.1.0, see ticket #5491
DROP FUNCTION IF EXISTS st_hillshade(raster, integer, text, double precision, double precision, double precision, double precision, boolean);
DROP FUNCTION IF EXISTS st_hillshade(raster, integer, text, float, float, float, float, boolean);
DROP FUNCTION IF EXISTS st_hillshade(raster, integer, text, float, float, float, float);
@@ -562,7 +560,6 @@ DROP FUNCTION IF EXISTS _add_raster_constraint_regular_blocking(name, name, name
-- function signature changed
DROP FUNCTION IF EXISTS st_asbinary(raster);
-DROP FUNCTION IF EXISTS _st_aspect4ma(float8[], text, text[]);
DROP FUNCTION IF EXISTS _st_hillshade4ma(float8[], text, text[]);
diff --git a/raster/test/regress/hooks/hook-after-upgrade-raster.sql b/raster/test/regress/hooks/hook-after-upgrade-raster.sql
index 950bf3631..59f57a7cc 100644
--- a/raster/test/regress/hooks/hook-after-upgrade-raster.sql
+++ b/raster/test/regress/hooks/hook-after-upgrade-raster.sql
@@ -6,6 +6,7 @@ DROP TABLE upgrade_test_raster;
DROP TABLE upgrade_test_raster_with_regular_blocking;
DROP VIEW upgrade_test_raster_view_st_slope;
+DROP VIEW upgrade_test_raster_view_st_aspect;
-- Drop functions deprecated on upgrade
DROP FUNCTION IF EXISTS st_value_deprecated_by_postgis_201(raster,geometry,boolean);
diff --git a/raster/test/regress/hooks/hook-before-upgrade-raster.sql b/raster/test/regress/hooks/hook-before-upgrade-raster.sql
index 92d64879b..58a6a1bc6 100644
--- a/raster/test/regress/hooks/hook-before-upgrade-raster.sql
+++ b/raster/test/regress/hooks/hook-before-upgrade-raster.sql
@@ -66,3 +66,9 @@ CREATE VIEW upgrade_test_raster_view_st_slope AS
SELECT
st_slope(NULL::raster, NULL::int, NULL::raster) sig1,
st_slope(NULL::raster, NULL::int) sig2;
+-- See https://trac.osgeo.org/postgis/ticket/5491
+CREATE VIEW upgrade_test_raster_view_st_aspect AS
+SELECT
+ st_aspect(NULL::raster, NULL::int, NULL::raster) sig1,
+ st_aspect(NULL::raster) sig2;
Summary of changes:
NEWS | 2 ++
raster/rt_pg/rtpostgis.sql.in | 17 +++++++++++++----
raster/rt_pg/rtpostgis_drop.sql.in | 5 +++++
raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in | 5 +----
raster/test/regress/hooks/hook-after-upgrade-raster.sql | 1 +
.../test/regress/hooks/hook-before-upgrade-raster.sql | 6 ++++++
6 files changed, 28 insertions(+), 8 deletions(-)
hooks/post-receive
