[postgis-tickets] [PostGIS] #5494: st_dwithin(text, text, float8) is marked as deprecated and installed by the same postgis version
PostGIS trac at osgeo.org
Tue Aug 29 12:55:16 PDT 2023
#5494: st_dwithin(text,text,float8) is marked as deprecated and installed by the
  Reporter:  strk      |      Owner:  pramsey
      Type:  defect    |     Status:  new
  Priority:  critical  |  Milestone:  PostGIS 3.1.10
 Component:  postgis   |    Version:  master
Resolution:            |   Keywords:  upgrade, deprecation, st_dwithin
Comment (by strk):
 The problem can be verified with this:
 echo 'select postgis_extensions_upgrade();' |
 make check-regress RUNTESTFLAGS="--extension --upgrade --after-upgrade-
 script /dev/stdin -v"
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5494#comment:6>
