[postgis-tickets] [PostGIS] #5494: st_dwithin(text, text, float8) is marked as deprecated and installed by the same postgis version
PostGIS trac at osgeo.org
Tue Aug 29 15:36:46 PDT 2023
#5494: st_dwithin(text,text,float8) is marked as deprecated and installed by the
  Reporter:  strk      |      Owner:  pramsey
      Type:  defect    |     Status:  new
  Priority:  critical  |  Milestone:  PostGIS 3.1.10
 Component:  postgis   |    Version:  master
Resolution:            |   Keywords:  upgrade, deprecation, st_dwithin
Comment (by Sandro Santilli <strk@…>):
 In [changeset:"bcf92c7d707d6930b5a6efb0016c391025755933/git" bcf92c7/git]:
 {{{#!CommitTicketReference repository="git"
 revision="bcf92c7d707d6930b5a6efb0016c391025755933"
 Allow requesting multiple upgrades to run_test.pl
 Pass multiple --upgrade switches to upgrade multiple times.
 It can be used to trigger bugs with still-existing functions
 being marked as deprecated.
 References #5494
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5494#comment:7>
