[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-78-g2cff24904
Wed Aug 30 05:07:38 PDT 2023
the project "PostGIS".
       via  2cff2490446fea9631a3c5b3ead9332e1e9716d3 (commit)
      from  a48a2382d0038b7db17a86532311954d257caddb (commit)
revisions in full, below.
commit 2cff2490446fea9631a3c5b3ead9332e1e9716d3
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Aug 30 14:04:52 2023 +0200
    Have after-upgrade hook drop view created by use-all-functions.sql
    Fixes `make -C regress check-locked-upgrade`
    Also encode some skips due to known bugs
    References #5497
diff --git a/regress/hooks/hook-after-upgrade.sql b/regress/hooks/hook-after-upgrade.sql
index 51faf3ef5..9e924fa30 100644
--- a/regress/hooks/hook-after-upgrade.sql
+++ b/regress/hooks/hook-after-upgrade.sql
@@ -25,3 +25,6 @@ DROP FUNCTION IF EXISTS st_dwithin_deprecated_by_postgis_300(geography,geography
 DROP FUNCTION IF EXISTS st_dwithin_deprecated_by_postgis_300(text,text,float8);
 DROP FUNCTION IF EXISTS st_clusterkmeans_deprecated_by_postgis_302(geometry,integer);
 DROP FUNCTION IF EXISTS st_distance_deprecated_by_postgis_300(geography,geography);
+DROP SCHEMA IF EXISTS postgis_upgrade_test_data CASCADE;
diff --git a/regress/hooks/use-all-functions.sql b/regress/hooks/use-all-functions.sql
index 46a24bb5a..1c59526d1 100644
--- a/regress/hooks/use-all-functions.sql
+++ b/regress/hooks/use-all-functions.sql
@@ -2,7 +2,8 @@ DO $BODY$
 DECLARE
 	rec RECORD;
 BEGIN
-	DROP VIEW IF EXISTS postgis_locking_view;
+	DROP SCHEMA IF EXISTS postgis_upgrade_test_data CASCADE;
+	CREATE SCHEMA postgis_upgrade_test_data;
 	FOR rec IN
 		SELECT
 			array_agg(
@@ -24,20 +25,46 @@ BEGIN
 				|| '::text as f' || oid
 			) f
 		FROM pg_catalog.pg_proc
-		WHERE proname like 'st\_%'
+		WHERE
+		-- We use the ST_ prefix as a sign that this function
+		-- belongs to PostGIS and is meant for public usage,
+		-- but the condition could be improved
+		proname like 'st\_%'
+		-- We only consider normal and window functions
+		-- ( not aggregates or procedures )
 		AND prokind in ('f','w')
-		-- See https://trac.osgeo.org/postgis/ticket/5498 and
-		-- remove when fixed
-		AND proname != 'st_approxquantile'
-		-- We skip functions taking anyelement for now
-		-- as those ones would need us to cast to some
-		-- real type
+		-- Skip function known to be problematic
+		AND proname NOT IN (
+			'fake'
+			,'st_approxquantile' -- https://trac.osgeo.org/postgis/ticket/5498
+--			,'st_mapalgebrafct' -- https://trac.osgeo.org/postgis/ticket/5500
+--			,'st_bandmetadata' -- unreported
+--			,'st_bandnodatavalue' -- unreported
+--			,'st_setgeoreference' -- unreported
+--			,'st_setbandisnodata' -- unreported
+--			,'st_setbandnodatavalue' -- unreported
+--			,'st_addband' -- unreported
+--			,'st_bandisnodata' -- unreported
+--			,'st_makeemptyraster' -- unreported
+--			,'st_bandpath' -- unreported
+--			,'st_bandpixeltype' -- unreported
+--			,'st_value' -- unreported
+--			,'st_georeference' -- unreported
+--			,'st_summarystats' -- unreported
+		AND oid::regprocedure::text NOT IN (
+			'fake'
+--			,'st_polygon(raster,integer)' -- unreported
+		-- Skip functions taking polymorphic arguments (anyelement)
+		-- as those ones would need us to cast to some real type.
 		AND proname NOT IN ( 'st_asmvt', 'st_fromflatgeobuf' )
-		-- We skip functions using VARIADIC or OUTPUT arguments
+		-- Skip functions using VARIADIC or OUTPUT arguments
 		AND ( NOT coalesce(proargmodes, '{}') && ARRAY['v'::"char",'o'] )
 	LOOP
 		EXECUTE format(
-			'CREATE VIEW postgis_locking_view AS SELECT %s',
+			'CREATE VIEW postgis_upgrade_test_data.locking_view AS SELECT %s',
 			array_to_string(rec.f, ',')
 	END LOOP;
Summary of changes:
 regress/hooks/hook-after-upgrade.sql |  3 +++
 regress/hooks/use-all-functions.sql  | 47 ++++++++++++++++++++++++++++--------
 2 files changed, 40 insertions(+), 10 deletions(-)
hooks/post-receive
