[postgis-tickets] [PostGIS] #5501: ERROR: cannot drop function st_clusterkmeans_deprecated_by_postgis_302(geometry, integer) because other objects depend on it
PostGIS trac at osgeo.org
Wed Aug 30 05:18:07 PDT 2023
st_clusterkmeans_deprecated_by_postgis_302(geometry,integer) because other
 Reporter:  strk                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  high                   |  Milestone:  PostGIS 3.4.1
Component:  build/upgrade/install  |    Version:  3.4.x
 Keywords:                         |
 FAIL: postgis extension upgrade 3.1.9dev--3.5.0dev
 Found with:
 MAKE_ARGS=TESTS=$PWD/regress/core/regress.sql RUNTESTFLAGS="-v --before-
 upgrade-script $PWD/regress/hooks/use-all-functions.sql"
 utils/check_all_upgrades.sh 3.5.0dev
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5501>
