[postgis-tickets] [PostGIS] #5501: ERROR: cannot drop function st_clusterkmeans_deprecated_by_postgis_302(geometry, integer) because other objects depend on it
PostGIS trac at osgeo.org
Wed Aug 30 05:21:28 PDT 2023
st_clusterkmeans_deprecated_by_postgis_302(geometry,integer) because other
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  high                   |  Milestone:  PostGIS 3.4.1
 Component:  build/upgrade/install  |    Version:  3.4.x
Resolution:                         |   Keywords:
Comment (by strk):
 An easier way to verify the bug:
 > make -C regress/ check-locked-upgrade RUNTESTFLAGS='--extension -v
 --upgrade-path 3.1.9dev--3.5.0dev'
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5501#comment:1>
