[postgis-tickets] [PostGIS] #5501: ERROR: cannot drop function st_clusterkmeans_deprecated_by_postgis_302(geometry, integer) because other objects depend on it
PostGIS trac at osgeo.org
Wed Aug 30 05:22:57 PDT 2023
st_clusterkmeans_deprecated_by_postgis_302(geometry,integer) because other
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  high                   |  Milestone:  PostGIS 3.4.1
 Component:  build/upgrade/install  |    Version:  3.4.x
Resolution:  invalid                |   Keywords:
Changes (by strk):
 * status:  new => closed
 * resolution:   => invalid
Comment:
 Sorry I now realize this is invalid, as the test is clearly missing
 dropping the view holding back the deprecated function
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5501#comment:2>
