[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-79-g148267b3d
Wed Aug 30 05:28:28 PDT 2023
the project "PostGIS".
       via  148267b3d26d7777f814cea4b7cb8743026e580c (commit)
      from  2cff2490446fea9631a3c5b3ead9332e1e9716d3 (commit)
revisions in full, below.
commit 148267b3d26d7777f814cea4b7cb8743026e580c
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Aug 30 14:27:35 2023 +0200
    Drop the upgrade test schema before the deprecated functions
    Ensures the deprecated functions can be removed safely
    References #5497
diff --git a/regress/hooks/hook-after-upgrade.sql b/regress/hooks/hook-after-upgrade.sql
index 9e924fa30..dfa5fc3eb 100644
--- a/regress/hooks/hook-after-upgrade.sql
+++ b/regress/hooks/hook-after-upgrade.sql
@@ -1,3 +1,4 @@
+-- TODO: move all these views and tables under postgis_upgrade_test_data
 DROP VIEW IF EXISTS upgrade_view_test_overlay;
 DROP VIEW IF EXISTS upgrade_view_test_unaryunion;
 DROP VIEW IF EXISTS upgrade_view_test_subdivide;
@@ -9,6 +10,8 @@ DROP VIEW IF EXISTS upgrade_view_test_clusterkmeans;
 DROP VIEW IF EXISTS upgrade_view_test_distance;
 DROP TABLE upgrade_test;
+DROP SCHEMA IF EXISTS postgis_upgrade_test_data CASCADE;
 -- Drop functions deprecated on upgrade
 DROP FUNCTION IF EXISTS st_force3dz_deprecated_by_postgis_301(geometry);
 DROP FUNCTION IF EXISTS st_force3d_deprecated_by_postgis_301(geometry);
@@ -26,5 +29,3 @@ DROP FUNCTION IF EXISTS st_dwithin_deprecated_by_postgis_300(text,text,float8);
 DROP FUNCTION IF EXISTS st_clusterkmeans_deprecated_by_postgis_302(geometry,integer);
 DROP FUNCTION IF EXISTS st_distance_deprecated_by_postgis_300(geography,geography);
-DROP SCHEMA IF EXISTS postgis_upgrade_test_data CASCADE;
Summary of changes:
 regress/hooks/hook-after-upgrade.sql | 5 +++--
 1 file changed, 3 insertions(+), 2 deletions(-)
hooks/post-receive
