[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-80-g27974085d
Wed Aug 30 05:45:05 PDT 2023
the project "PostGIS".
       via  27974085d757e4f56a4f9a5c9956e40acd403829 (commit)
      from  148267b3d26d7777f814cea4b7cb8743026e580c (commit)
revisions in full, below.
commit 27974085d757e4f56a4f9a5c9956e40acd403829
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Aug 30 14:43:47 2023 +0200
    Drop any deprecated_by_postgis function after upgrade test
    Fixes `make -C regress/ check-locked-upgrade` for real
    References #5497
diff --git a/regress/hooks/hook-after-upgrade.sql b/regress/hooks/hook-after-upgrade.sql
index dfa5fc3eb..ef6ea0d15 100644
--- a/regress/hooks/hook-after-upgrade.sql
+++ b/regress/hooks/hook-after-upgrade.sql
@@ -10,22 +10,20 @@ DROP VIEW IF EXISTS upgrade_view_test_clusterkmeans;
 DROP VIEW IF EXISTS upgrade_view_test_distance;
 DROP TABLE upgrade_test;
+-- Drop any upgrade test data
 DROP SCHEMA IF EXISTS postgis_upgrade_test_data CASCADE;
 -- Drop functions deprecated on upgrade
-DROP FUNCTION IF EXISTS st_force3dz_deprecated_by_postgis_301(geometry);
-DROP FUNCTION IF EXISTS st_force3d_deprecated_by_postgis_301(geometry);
-DROP FUNCTION IF EXISTS st_force3dm_deprecated_by_postgis_301(geometry);
-DROP FUNCTION IF EXISTS st_force4d_deprecated_by_postgis_301(geometry);
-DROP FUNCTION IF EXISTS st_intersection_deprecated_by_postgis_301(geometry,geometry);
-DROP FUNCTION IF EXISTS st_difference_deprecated_by_postgis_301(geometry,geometry);
-DROP FUNCTION IF EXISTS st_symdifference_deprecated_by_postgis_301(geometry,geometry);
-DROP FUNCTION IF EXISTS st_unaryunion_deprecated_by_postgis_301(geometry);
-DROP FUNCTION IF EXISTS st_subdivide_deprecated_by_postgis_301(geometry,integer);
-DROP FUNCTION IF EXISTS st_askml_deprecated_by_postgis_200(geometry,integer);
-DROP FUNCTION IF EXISTS st_askml_deprecated_by_postgis_200(geography,integer);
-DROP FUNCTION IF EXISTS st_dwithin_deprecated_by_postgis_300(geography,geography,float8);
-DROP FUNCTION IF EXISTS st_dwithin_deprecated_by_postgis_300(text,text,float8);
-DROP FUNCTION IF EXISTS st_clusterkmeans_deprecated_by_postgis_302(geometry,integer);
-DROP FUNCTION IF EXISTS st_distance_deprecated_by_postgis_300(geography,geography);
+DO LANGUAGE 'plpgsql' $DROPALL$
+DECLARE
+	rec pg_catalog.pg_proc;
+BEGIN
+	FOR rec IN
+		SELECT * FROM pg_catalog.pg_proc
+		WHERE proname ~ '_deprecated_by_postgis'
+	LOOP
+		RAISE NOTICE 'Dropping function %', rec.oid::regprocedure;
+		EXECUTE pg_catalog.format('DROP FUNCTION %s', rec.oid::regprocedure);
+	END LOOP;
+END;
+$DROPALL$;
Summary of changes:
 regress/hooks/hook-after-upgrade.sql | 30 ++++++++++++++----------------
 1 file changed, 14 insertions(+), 16 deletions(-)
hooks/post-receive
