[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-82-ga83e783e0
git at osgeo.org
git at osgeo.org
Wed Aug 30 06:28:01 PDT 2023
the project "PostGIS".
via a83e783e0aa91e99fd279623490adb4fd0a331a7 (commit)
via 00a73cfc520eafeab38d70289cf47ed3d0335838 (commit)
from 27974085d757e4f56a4f9a5c9956e40acd403829 (commit)
revisions in full, below.
commit a83e783e0aa91e99fd279623490adb4fd0a331a7
Author: Sandro Santilli <strk at kbt.io>
Date: Wed Aug 30 15:27:40 2023 +0200
Have dronie and woodie test locked upgrade of topology
diff --git a/ci/dronie/postgis_regress.sh b/ci/dronie/postgis_regress.sh
index 188bbb451..5d9a737a3 100644
--- a/ci/dronie/postgis_regress.sh
+++ b/ci/dronie/postgis_regress.sh
@@ -32,6 +32,10 @@ RUNTESTFLAGS=-v make check
RUNTESTFLAGS=-v make check-double-upgrade
RUNTESTFLAGS=-v make -C regress check-locked-upgrade
+RUNTESTFLAGS=-v make -C topology/test check-locked-upgrade
+# This is blocked by https://trac.osgeo.org/postgis/ticket/5500
+#RUNTESTFLAGS=-v make -C raster/test/regress check-locked-upgrade
# Install
commit 00a73cfc520eafeab38d70289cf47ed3d0335838
Date: Wed Aug 30 15:17:43 2023 +0200
Fix `check-locked-upgrade` for topology
diff --git a/regress/hooks/hook-after-upgrade.sql b/regress/hooks/hook-after-upgrade.sql
index ef6ea0d15..c0516610d 100644
--- a/regress/hooks/hook-after-upgrade.sql
+++ b/regress/hooks/hook-after-upgrade.sql
@@ -8,7 +8,7 @@ DROP VIEW IF EXISTS upgrade_view_test_askml;
DROP VIEW IF EXISTS upgrade_view_test_dwithin;
DROP VIEW IF EXISTS upgrade_view_test_clusterkmeans;
DROP VIEW IF EXISTS upgrade_view_test_distance;
-DROP TABLE upgrade_test;
+DROP TABLE IF EXISTS upgrade_test;
-- Drop any upgrade test data
DROP SCHEMA IF EXISTS postgis_upgrade_test_data CASCADE;
diff --git a/regress/runtest.mk b/regress/runtest.mk
index aba9a6756..b56632869 100644
--- a/regress/runtest.mk
+++ b/regress/runtest.mk
@@ -48,5 +48,7 @@ check-double-upgrade:
.PHONY: check-locked-upgrade
check-locked-upgrade:
$(MAKE) check-regress \
- RUNTESTFLAGS="$(RUNTESTFLAGS) --upgrade --before-upgrade-script $(top_srcdir)/regress/hooks/use-all-functions.sql" \
+ RUNTESTFLAGS="$(RUNTESTFLAGS) --upgrade \
+ --before-upgrade-script $(top_srcdir)/regress/hooks/use-all-functions.sql \
+ --after-upgrade-script $(top_srcdir)/regress/hooks/hook-after-upgrade.sql " \
TESTS=$(top_srcdir)/regress/core/regress.sql
Summary of changes:
ci/dronie/postgis_regress.sh | 4 ++++
regress/hooks/hook-after-upgrade.sql | 2 +-
regress/runtest.mk | 4 +++-
3 files changed, 8 insertions(+), 2 deletions(-)
hooks/post-receive
