[postgis-tickets] [PostGIS] #5502: ERROR: cannot drop function st_bandmetadata(raster, integer) because other objects depend on it
PostGIS trac at osgeo.org
Wed Aug 30 09:21:58 PDT 2023
#5502: ERROR:  cannot drop function st_bandmetadata(raster,integer) because other
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.4.1
 Component:  build/upgrade/install  |    Version:  3.4.x
Resolution:                         |   Keywords:  raster
Comment (by strk):
 Hold on, taking it back, the signature actually changed from using OUT
 parameters to returning table. This happened in 2.5.0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5502#comment:2>
