[postgis-tickets] [PostGIS] #5502: ERROR: cannot drop function st_bandmetadata(raster, integer) because other objects depend on it
PostGIS trac at osgeo.org
Wed Aug 30 10:10:09 PDT 2023
#5502: ERROR:  cannot drop function st_bandmetadata(raster,integer) because other
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.4.1
 Component:  build/upgrade/install  |    Version:  3.4.x
Resolution:                         |   Keywords:  raster
Comment (by strk):
 We'll need `pg_catalog.pg_get_function_identity_arguments` to spot the
 difference, which goes from:
 > rast raster, band integer[], OUT bandnum integer, OUT pixeltype text,
 OUT nodatavalue double precision, OUT isoutdb boolean, OUT path text, OUT
 outdbbandnum integer, OUT filesize bigint, OUT filetimestamp bigint
 to:
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5502#comment:3>
