[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-89-ge1a3381fa
Thu Aug 31 10:50:26 PDT 2023
the project "PostGIS".
       via  e1a3381fa706532b54108a762df6129d0aedce4e (commit)
       via  684daa95388dcb11fb553a3976210dd5f36958ab (commit)
       via  8db554622ce2c2c3c4d3b7c412cb3011b13b075c (commit)
      from  e9df66644c4a2d40b10f1946a32efba23c3041af (commit)
revisions in full, below.
commit e1a3381fa706532b54108a762df6129d0aedce4e
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Aug 31 16:01:36 2023 +0200
    Try to drop all deprecated functions at the end of upgrade
diff --git a/.editorconfig b/.editorconfig
index 652bb84ad..03b109bda 100644
--- a/.editorconfig
+++ b/.editorconfig
@@ -82,3 +82,7 @@ indent_size = 4
 [*.xsl]
 indent_style = tab
+[postgis/common_after_upgrade.sql]
+indent_style = space
+indent_size = 4
diff --git a/postgis/common_after_upgrade.sql b/postgis/common_after_upgrade.sql
index fad82565f..45873e722 100644
--- a/postgis/common_after_upgrade.sql
+++ b/postgis/common_after_upgrade.sql
@@ -21,3 +21,80 @@
 -- DROP auxiliar function (created by common_before_upgrade.sql)
 DROP FUNCTION _postgis_drop_function_if_needed(text, text, text);
+-- Drop deprecated functions if possible
+DO LANGUAGE 'plpgsql'
+$POSTGIS_PROC_UPGRADE$
+DECLARE
+    new_name TEXT;
+    rec RECORD;
+    extrec RECORD;
+    sql TEXT;
+    detail TEXT;
+    hint TEXT;
+BEGIN
+    -- Try to drop all deprecated functions,
+    -- and report failure to do so as a WARNING
+    -- for the user to handle.
+    FOR rec IN
+        SELECT *, oid::regprocedure as proc
+        FROM pg_catalog.pg_proc
+        WHERE proname ~ 'deprecated_by_postgis'
+    LOOP --{
+        RAISE DEBUG 'Handling deprecated function %', rec.proc;
+        new_name := pg_catalog.regexp_replace(
+            rec.proc::text,
+            '_deprecated_by_postgis[^(]*\(.*',
+        sql := pg_catalog.format('DROP FUNCTION %s', rec.proc);
+        --RAISE DEBUG 'SQL: %', sql;
+        BEGIN --{
+            EXECUTE sql;
+        EXCEPTION
+        WHEN OTHERS THEN -- }{
+            hint = 'Resolve the issue';
+            GET STACKED DIAGNOSTICS detail := PG_EXCEPTION_DETAIL;
+            IF detail LIKE '%view % depends%' THEN
+                hint = pg_catalog.format(
+                    'Replace the view changing all occurrences of %s in its definition with %s',
+                    rec.proc,
+                    new_name
+            END IF;
+            hint = hint || ' and upgrade again';
+            RAISE WARNING 'Deprecated function % left behind: %',
+                rec.proc, SQLERRM
+            USING DETAIL = detail, HINT = hint;
+            -- Drop the function from any extension it is part of
+            -- so dump/reloads still work
+            FOR extrec IN
+                SELECT e.extname
+                FROM
+                    pg_catalog.pg_extension e,
+                    pg_catalog.pg_depend d
+                WHERE
+                    d.refclassid = 'pg_catalog.pg_extension'::pg_catalog.regclass AND
+                    d.refobjid = e.oid AND
+                    d.classid = 'pg_catalog.pg_proc'::pg_catalog.regclass AND
+                    d.objid = rec.proc::oid
+            LOOP
+                RAISE DEBUG 'Unpackaging % from extension %', rec.proc, extrec.extname;
+                sql := pg_catalog.format('ALTER EXTENSION %I DROP FUNCTION %s', extrec.extname, rec.proc);
+                EXECUTE sql;
+            END LOOP;
+        END; --}
+    END LOOP; --}
+END
+$POSTGIS_PROC_UPGRADE$;
diff --git a/utils/create_upgrade.pl b/utils/create_upgrade.pl
index eeaf4ed43..5de18a8a1 100755
--- a/utils/create_upgrade.pl
+++ b/utils/create_upgrade.pl
@@ -666,173 +666,6 @@ EOF
     $comment = '';
-# If any deprecated function still exist, drop it now
-my $deprecated_names = '{' . ( join ',', @renamed_deprecated_functions) . '}';
-print <<"EOF";
--- Drop deprecated functions if possible
-DO LANGUAGE 'plpgsql'
-\$postgis_proc_upgrade\$
-DECLARE
-    deprecated_functions regprocedure[];
-    new_name TEXT;
-    rewrote_as_wrapper BOOLEAN;
-    rec RECORD;
-    extrec RECORD;
-    procrec RECORD;
-    sql TEXT;
-    detail TEXT;
-    hint TEXT;
-BEGIN
-    -- Fetch a list of deprecated functions
-    SELECT array_agg(oid::regprocedure)
-    FROM pg_catalog.pg_proc
-    WHERE proname = ANY ('${deprecated_names}'::name[])
-    INTO deprecated_functions;
-    RAISE DEBUG 'Handling deprecated functions: %', deprecated_functions;
---    -- Rewrite views using deprecated functions
---    -- to improve the odds of being able to drop them
---    FOR rec IN
---        SELECT n.nspname AS schemaname,
---            c.relname AS viewname,
---            pg_catalog.pg_get_userbyid(c.relowner) AS viewowner,
---            pg_catalog.pg_get_viewdef(c.oid) AS definition,
---            CASE
---                WHEN 'check_option=cascaded' = ANY (c.reloptions) THEN 'WITH CASCADED CHECK OPTION'
---                WHEN 'check_option=local' = ANY (c.reloptions) THEN 'WITH LOCAL CHECK OPTION'
---                ELSE ''
---            END::text AS check_option
---        FROM pg_catalog.pg_class c
---        LEFT JOIN pg_catalog.pg_namespace n ON n.oid = c.relnamespace
---        WHERE c.relkind = 'v'
---        AND pg_catalog.pg_get_viewdef(c.oid) ~ 'deprecated_by_postgis'
---    LOOP
---        sql := pg_catalog.format('CREATE OR REPLACE VIEW %I.%I AS %s %s',
---            rec.schemaname,
---            rec.viewname,
---            pg_catalog.regexp_replace(rec.definition, '_deprecated_by_postgis_[^(]*', '', 'g'),
---            rec.check_option
---        RAISE NOTICE 'Updating view % to not use deprecated signatures', rec.viewname;
---        BEGIN
---            EXECUTE sql;
---        EXCEPTION
---        WHEN OTHERS THEN
---                GET STACKED DIAGNOSTICS detail := PG_EXCEPTION_DETAIL;
---                RAISE WARNING 'Could not rewrite view % using deprecated functions', rec.viewname
---                        USING DETAIL = pg_catalog.format('%s: %s', SQLERRM, detail);
---        END;
---    END LOOP;
-    -- Try to drop all deprecated functions, or rewrite those
-    -- who cannot be drop and rewrite them in SQL
-    FOR rec IN SELECT pg_catalog.unnest(deprecated_functions) as proc
-    LOOP --{
-        RAISE DEBUG 'Handling deprecated function %', rec.proc;
-        new_name := pg_catalog.regexp_replace(
-            rec.proc::text,
-            '_deprecated_by_postgis[^(]*\\(.*',
-        sql := pg_catalog.format('DROP FUNCTION %s', rec.proc);
-        --RAISE DEBUG 'SQL: %', sql;
-        BEGIN
-            EXECUTE sql;
-        EXCEPTION
-        WHEN OTHERS THEN
-            hint = 'Resolve the issue';
-            IF detail LIKE '%view % depends%' THEN
-                hint = pg_catalog.format(
-                    'Replace the view changing all occurrences of %s in its definition with %s',
-                    rec.proc,
-                    new_name
-            END IF;
-            hint = hint || ' and upgrade again';
-            RAISE WARNING 'Deprecated function % left behind: %',
-                rec.proc, SQLERRM
-            USING DETAIL = detail, HINT = hint;
-            -- Try to rewrite the function as an SQL WRAPPER
-            SELECT pg_get_functiondef(oid) def, pronargs
-            FROM pg_catalog.pg_proc WHERE oid = rec.proc
-            INTO procrec;
-            -- TODO: don't even try if it's an aggregate or windowing
-            --       function (procrec.prokind)
-            -- TODO: don't even try if it's a scripting language function
-            -- Force LANGUAGE to be SQL
-            sql := pg_catalog.regexp_replace(procrec.def, 'LANGUAGE [^ \n]*', 'LANGUAGE sql');
-            --RAISE DEBUG 'SQL (LANGUAGE): %', sql;
-            -- Change body to be a wrapper
-                sql,
-                -- Find a stricted match here ?
-                'AS .*',
-                pg_catalog.format(
-                    -- TODO: have the function raise a warning too ?
-                    'AS \$\$ SELECT %s(%s) \$\$',
-                    new_name,
-                        SELECT array_to_string(
-                            array_agg('\$' || x),
-                        FROM generate_series(1, procrec.pronargs) x
-            RAISE DEBUG 'SQL: %', sql;
-            rewrote_as_wrapper := false;
-            BEGIN
-                EXECUTE sql;
-                rewrote_as_wrapper := true;
-            EXCEPTION
-            WHEN OTHERS THEN
-                RAISE WARNING
-                    'Deprecated function % could not be rewritten as a wrapper: % (%)',
-                    rec.proc, SQLERRM, SQLSTATE;
-            END;
-            -- Drop the function from any extension it is part of
-            -- so dump/reloads still work
-            FOR extrec IN
-                SELECT e.extname
-                FROM
-                    pg_catalog.pg_extension e,
-                    pg_catalog.pg_depend d
-                WHERE
-                    d.refclassid = 'pg_catalog.pg_extension'::pg_catalog.regclass AND
-                    d.refobjid = e.oid AND
-                    d.classid = 'pg_catalog.pg_proc'::pg_catalog.regclass AND
-                    d.objid = rec.proc::oid
-            LOOP
-                RAISE DEBUG 'Unpackaging % from extension %', rec.proc, extrec.extname;
-                sql := pg_catalog.format('ALTER EXTENSION %I DROP FUNCTION %s', extrec.extname, rec.proc);
-                EXECUTE sql;
-            END LOOP;
-        END;
-    END LOOP; --}
-END
-\$postgis_proc_upgrade\$;
-EOF
 close(INPUT);
 print "DROP FUNCTION _postgis_upgrade_info();\n";
commit 684daa95388dcb11fb553a3976210dd5f36958ab
Date:   Thu Aug 31 13:13:14 2023 +0200
    Have _postgis_drop_function_if_needed rename rather than drop
    Renames functions to have suffix _deprecated_by_postgis_<version>
    Version becomes an optional parameter.
    References #5493
index 87544acbd..fad82565f 100644
@@ -19,5 +19,5 @@
-DROP FUNCTION _postgis_drop_function_if_needed(text, text);
+DROP FUNCTION _postgis_drop_function_if_needed(text, text, text);
diff --git a/postgis/common_before_upgrade.sql b/postgis/common_before_upgrade.sql
index 878cc9545..210ca0ab9 100644
--- a/postgis/common_before_upgrade.sql
+++ b/postgis/common_before_upgrade.sql
@@ -34,11 +34,15 @@
 --         ORDER BY 1, 2, 3, 4;
 CREATE OR REPLACE FUNCTION _postgis_drop_function_if_needed(
 	function_name text,
-	function_arguments text) RETURNS void AS $$
+	function_arguments text,
+	deprecated_in_version text DEFAULT 'xxx'
+) RETURNS void AS $$
 DECLARE
-	sql_drop text;
+	sql text;
 	postgis_namespace OID;
-	matching_function REGPROCEDURE;
+	matching_function pg_catalog.pg_proc;
+	detail TEXT;
+	deprecated_suffix TEXT := '_deprecated_by_postgis_' || deprecated_in_version;
 BEGIN
 	-- Fetch install namespace for PostGIS
@@ -49,7 +53,7 @@ BEGIN
 	INTO postgis_namespace;
 	-- Find a function matching the given signature
-	SELECT oid
+	SELECT *
 	FROM pg_catalog.pg_proc p
 	WHERE pronamespace = postgis_namespace
 	AND pg_catalog.LOWER(p.proname) = pg_catalog.LOWER(function_name)
@@ -57,14 +61,20 @@ BEGIN
 	AND pg_catalog.LOWER(pg_catalog.pg_get_function_identity_arguments(p.oid)) ~ pg_catalog.LOWER(function_arguments)
 	INTO matching_function;
-	IF matching_function IS NOT NULL THEN
-		sql_drop := 'DROP FUNCTION ' || matching_function;
-		RAISE DEBUG 'SQL query: %', sql_drop;
+	IF matching_function.oid IS NOT NULL THEN
+		sql := format('ALTER FUNCTION %s RENAME TO %I',
+			matching_function.oid::regprocedure,
+			matching_function.proname || deprecated_suffix
+		RAISE WARNING 'SQL query: %', sql;
 		BEGIN
-			EXECUTE sql_drop;
+			EXECUTE sql;
 		EXCEPTION
 			WHEN OTHERS THEN
-				RAISE EXCEPTION 'Could not drop function %. You might need to drop dependant objects. Postgres error: %', function_name, SQLERRM;
+				RAISE EXCEPTION 'Could not rename deprecated function %, got % (%)',
+					matching_function, SQLERRM, SQLSTATE
+				USING DETAIL = detail;
 		END;
 	END IF;
commit 8db554622ce2c2c3c4d3b7c412cb3011b13b075c
Date:   Thu Aug 31 09:52:41 2023 +0200
    Use a common before/after upgrade script for core and raster
    References #5493
diff --git a/extensions/postgis/Makefile.in b/extensions/postgis/Makefile.in
index 09ccc8c08..799fdf925 100644
--- a/extensions/postgis/Makefile.in
+++ b/extensions/postgis/Makefile.in
@@ -116,7 +116,8 @@ sql/spatial_ref_sys.sql: ../../spatial_ref_sys.sql | sql
 sql/spatial_ref_sys_config_dump.sql: ../../spatial_ref_sys.sql ../../utils/create_spatial_ref_sys_config_dump.pl | sql
 	$(PERL) @top_srcdir@/utils/create_spatial_ref_sys_config_dump.pl $< > $@
-sql/postgis_upgrade_for_extension.sql: ../../postgis/postgis_before_upgrade.sql sql/postgis_upgrade_for_extension.sql.in ../../postgis/postgis_after_upgrade.sql | sql
+#this keeps the @extschema at . in place since extension machinery will replace during install
+sql/postgis_upgrade_for_extension.sql: ../../postgis/common_before_upgrade.sql ../../postgis/postgis_before_upgrade.sql sql/postgis_upgrade_for_extension.sql.in ../../postgis/postgis_after_upgrade.sql ../../postgis/common_after_upgrade.sql | sql
 	#strip BEGIN/COMMIT since these are not allowed in extensions
 	# WARNING: we should make sure these are not internal to function bodies
 	cat $^ | $(PERL) -pe 's/BEGIN\;//g ; s/COMMIT\;//g' > $@
diff --git a/extensions/postgis_raster/Makefile.in b/extensions/postgis_raster/Makefile.in
index ceb0eade2..4a2af9502 100644
--- a/extensions/postgis_raster/Makefile.in
+++ b/extensions/postgis_raster/Makefile.in
@@ -102,7 +102,7 @@ sql/rtpostgis_upgrade.sql: sql/rtpostgis_upgrade_for_extension.sql | sql
 	$(PERL) -pe "s/BEGIN\;//g ; s/COMMIT\;//g; s/^(DROP .*)\;/SELECT postgis_extension_drop_if_exists('$(EXTENSION)', '\1');\n\1\;/" $< > $@
-sql/rtpostgis_upgrade_for_extension.sql: ../../raster/rt_pg/rtpostgis_upgrade_cleanup.sql sql/rtpostgis_upgrade_for_extension.sql.in ../../raster/rt_pg/rtpostgis_drop.sql | sql
+sql/rtpostgis_upgrade_for_extension.sql: ../../postgis/common_before_upgrade.sql ../../raster/rt_pg/rtpostgis_upgrade_cleanup.sql sql/rtpostgis_upgrade_for_extension.sql.in ../../raster/rt_pg/rtpostgis_drop.sql ../../postgis/common_after_upgrade.sql | sql
 	echo 'BEGIN;' > $@
 	cat $^ | sed -e 's/^BEGIN;$$//' -e 's/^COMMIT;$$//' >> $@
 	echo 'COMMIT;' >> $@
diff --git a/postgis/Makefile.in b/postgis/Makefile.in
index 095d1b300..0e972da7e 100644
--- a/postgis/Makefile.in
+++ b/postgis/Makefile.in
@@ -236,6 +236,10 @@ endif
 # Borrow the $libdir substitution from PGXS but customise by running the preprocessor
 # and adding the version number
 # replace @extschema at . with nothing, this is only used as placeholder for extension install
+# TODO: create an intermediate product with @extschema@ in place, to reduce rules duplications
+#       in the extension/ folder
 %.sql: %.sql.in
 	$(SQLPP) -I at top_srcdir@/libpgcommon -I at builddir@ $< > $@.tmp
 	grep -v '^#' $@.tmp | $(PERL) -lpe "s'MODULE_PATHNAME'\$(MODULEPATH)'g;s'@extschema@\.''g" > $@
@@ -246,7 +250,7 @@ postgis_upgrade.sql.in: postgis.sql ../utils/create_upgrade.pl
 	$(PERL) @top_srcdir@/utils/create_upgrade.pl $< > $@
-postgis_upgrade.sql: postgis_before_upgrade.sql postgis_upgrade.sql.in postgis_after_upgrade.sql
+postgis_upgrade.sql: common_before_upgrade.sql postgis_before_upgrade.sql postgis_upgrade.sql.in postgis_after_upgrade.sql common_after_upgrade.sql
 	echo "BEGIN;" > $@
 	cat $^ >> $@
 	echo "COMMIT;" >> $@
new file mode 100644
index 000000000..87544acbd
--- /dev/null
@@ -0,0 +1,23 @@
+-- PostGIS - Spatial Types for PostgreSQL
+-- http://postgis.net
+-- Copyright (C) 2011-2020 Sandro Santilli <strk at kbt.io>
+-- Copyright (C) 2010-2012 Regina Obe <lr at pcorp.us>
+-- Copyright (C) 2009      Paul Ramsey <pramsey at cleverelephant.ca>
+-- This is free software; you can redistribute and/or modify it under
+-- the terms of the GNU General Public Licence. See the COPYING file.
+-- This file will be appended at the very end of every
+-- sql upgrade script.
+-- DROP auxiliar function (created by common_before_upgrade.sql)
+DROP FUNCTION _postgis_drop_function_if_needed(text, text);
index 000000000..878cc9545
--- /dev/null
@@ -0,0 +1,72 @@
+-- Copyright (C) 2011-2012 Sandro Santilli <strk at kbt.io>
+-- Copyright (C) 2010-2013 Regina Obe <lr at pcorp.us>
+-- This file contains utility functions for use by upgrade scripts
+-- Changes to this file affect *upgrade*.sql script.
+-- Helper function to drop functions when they match the full signature
+-- Requires schema, name and __exact arguments__ as extracted from pg_catalog.pg_get_function_arguments
+-- You can extract the old function arguments using a query like:
+-- SELECT  p.oid as oid,
+--                 n.nspname as schema,
+--                 p.proname as name,
+--                 pg_catalog.pg_get_function_arguments(p.oid) as arguments
+--         FROM pg_catalog.pg_proc p
+--         LEFT JOIN pg_catalog.pg_namespace n ON n.oid = p.pronamespace
+--         WHERE
+--                 pg_catalog.LOWER(n.nspname) = pg_catalog.LOWER('public') AND
+--                 pg_catalog.LOWER(p.proname) = pg_catalog.LOWER('ST_AsGeoJson')
+--         ORDER BY 1, 2, 3, 4;
+CREATE OR REPLACE FUNCTION _postgis_drop_function_if_needed(
+	function_name text,
+	function_arguments text) RETURNS void AS $$
+DECLARE
+	sql_drop text;
+	postgis_namespace OID;
+	matching_function REGPROCEDURE;
+BEGIN
+	-- Fetch install namespace for PostGIS
+	SELECT n.oid
+	FROM pg_catalog.pg_proc p
+	JOIN pg_catalog.pg_namespace n ON p.pronamespace = n.oid
+	WHERE proname = 'postgis_full_version'
+	INTO postgis_namespace;
+	-- Find a function matching the given signature
+	SELECT oid
+	WHERE pronamespace = postgis_namespace
+	AND pg_catalog.LOWER(p.proname) = pg_catalog.LOWER(function_name)
+	AND pg_catalog.pg_function_is_visible(p.oid)
+	AND pg_catalog.LOWER(pg_catalog.pg_get_function_identity_arguments(p.oid)) ~ pg_catalog.LOWER(function_arguments)
+	INTO matching_function;
+	IF matching_function IS NOT NULL THEN
+		sql_drop := 'DROP FUNCTION ' || matching_function;
+		RAISE DEBUG 'SQL query: %', sql_drop;
+		BEGIN
+			EXECUTE sql_drop;
+		EXCEPTION
+			WHEN OTHERS THEN
+				RAISE EXCEPTION 'Could not drop function %. You might need to drop dependant objects. Postgres error: %', function_name, SQLERRM;
+		END;
+	END IF;
+END;
+$$ LANGUAGE plpgsql;
diff --git a/postgis/postgis_before_upgrade.sql b/postgis/postgis_before_upgrade.sql
index da945fc44..f8607f216 100644
--- a/postgis/postgis_before_upgrade.sql
+++ b/postgis/postgis_before_upgrade.sql
@@ -20,59 +20,6 @@
--- Helper function to drop functions when they match the full signature
--- Requires schema, name and __exact arguments__ as extracted from pg_catalog.pg_get_function_arguments
--- You can extract the old function arguments using a query like:
--- SELECT  p.oid as oid,
---                 n.nspname as schema,
---                 p.proname as name,
---                 pg_catalog.pg_get_function_arguments(p.oid) as arguments
---         FROM pg_catalog.pg_proc p
---         LEFT JOIN pg_catalog.pg_namespace n ON n.oid = p.pronamespace
---         WHERE
---                 pg_catalog.LOWER(n.nspname) = pg_catalog.LOWER('public') AND
---                 pg_catalog.LOWER(p.proname) = pg_catalog.LOWER('ST_AsGeoJson')
---         ORDER BY 1, 2, 3, 4;
-CREATE OR REPLACE FUNCTION _postgis_drop_function_if_needed(
-	function_name text,
-DECLARE
-	sql_drop text;
-	postgis_namespace OID;
-BEGIN
-	-- Fetch install namespace for PostGIS
-	SELECT n.oid
-	JOIN pg_catalog.pg_namespace n ON p.pronamespace = n.oid
-	WHERE proname = 'postgis_full_version'
-	INTO postgis_namespace;
-	-- Find a function matching the given signature
-	SELECT oid
-	WHERE pronamespace = postgis_namespace
-	AND pg_catalog.LOWER(p.proname) = pg_catalog.LOWER(function_name)
-	AND pg_catalog.pg_function_is_visible(p.oid)
-	AND pg_catalog.LOWER(pg_catalog.pg_get_function_identity_arguments(p.oid)) ~ pg_catalog.LOWER(function_arguments)
-	INTO matching_function;
-		BEGIN
-			EXECUTE sql_drop;
-		EXCEPTION
-			WHEN OTHERS THEN
-		END;
-	END IF;
-END;
-$$ LANGUAGE plpgsql;
 -- FUNCTION AddGeometryColumn signature dropped
 -- (catalog_name character varying, schema_name character varying, table_name character varying, column_name character varying, new_srid integer, new_type character varying, new_dim integer, use_typmod boolean)
 SELECT _postgis_drop_function_if_needed
@@ -235,7 +182,3 @@ BEGIN
 END;
--- DROP auxiliar function (created above)
diff --git a/raster/rt_pg/Makefile.in b/raster/rt_pg/Makefile.in
index 4fa8a748c..7b0627fe9 100644
--- a/raster/rt_pg/Makefile.in
+++ b/raster/rt_pg/Makefile.in
@@ -124,6 +124,10 @@ endif
 %.sql: %.sql.in
 	$(SQLPP) -I at top_builddir@/postgis/ $< > $@.tmp
 	grep -v '^#' $@.tmp | \
@@ -151,7 +155,7 @@ $(SQL_OBJS): ../../postgis/sqldefines.h ../../postgis_revision.h
 rtpostgis_upgrade.sql.in: rtpostgis.sql ../../utils/create_upgrade.pl
-rtpostgis_upgrade.sql: rtpostgis_upgrade_cleanup.sql rtpostgis_upgrade.sql.in rtpostgis_drop.sql
+rtpostgis_upgrade.sql: ../../postgis/common_before_upgrade.sql rtpostgis_upgrade_cleanup.sql rtpostgis_upgrade.sql.in rtpostgis_drop.sql ../../postgis/common_after_upgrade.sql
 	echo 'BEGIN;' > $@
Summary of changes:
 .editorconfig                         |   4 +
 extensions/postgis/Makefile.in        |   3 +-
 extensions/postgis_raster/Makefile.in |   2 +-
 postgis/Makefile.in                   |   6 +-
 postgis/common_after_upgrade.sql      | 100 ++++++++++++++++++++
 postgis/common_before_upgrade.sql     |  82 +++++++++++++++++
 postgis/postgis_before_upgrade.sql    |  57 ------------
 raster/rt_pg/Makefile.in              |   6 +-
 utils/create_upgrade.pl               | 167 ----------------------------------
 9 files changed, 199 insertions(+), 228 deletions(-)
 create mode 100644 postgis/common_after_upgrade.sql
 create mode 100644 postgis/common_before_upgrade.sql
hooks/post-receive
