[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-91-g3a831d5c6
Thu Aug 31 14:20:45 PDT 2023
the project "PostGIS".
       via  3a831d5c6ccde943da253e6ca932c483d4179348 (commit)
       via  49ddd911f69b7843bda7a8c06c44bf3de91f20b5 (commit)
      from  e1a3381fa706532b54108a762df6129d0aedce4e (commit)
revisions in full, below.
commit 3a831d5c6ccde943da253e6ca932c483d4179348
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Aug 31 21:02:48 2023 +0200
    Add common function to drop by signature rather than identity
diff --git a/postgis/common_after_upgrade.sql b/postgis/common_after_upgrade.sql
index 45873e722..09f9ea2a4 100644
--- a/postgis/common_after_upgrade.sql
+++ b/postgis/common_after_upgrade.sql
@@ -19,7 +19,8 @@
 -- DROP auxiliar function (created by common_before_upgrade.sql)
-DROP FUNCTION _postgis_drop_function_if_needed(text, text, text);
+DROP FUNCTION _postgis_drop_function_by_identity(text, text, text);
+DROP FUNCTION _postgis_drop_function_by_signature(text, text);
 -- Drop deprecated functions if possible
diff --git a/postgis/common_before_upgrade.sql b/postgis/common_before_upgrade.sql
index 210ca0ab9..a6389faef 100644
--- a/postgis/common_before_upgrade.sql
+++ b/postgis/common_before_upgrade.sql
@@ -20,19 +20,19 @@
 -- Helper function to drop functions when they match the full signature
--- Requires schema, name and __exact arguments__ as extracted from pg_catalog.pg_get_function_arguments
+-- Requires name and __exact arguments__ as extracted from pg_catalog.pg_get_function_arguments
 -- You can extract the old function arguments using a query like:
--- SELECT  p.oid as oid,
---                 n.nspname as schema,
---                 p.proname as name,
---                 pg_catalog.pg_get_function_arguments(p.oid) as arguments
---         FROM pg_catalog.pg_proc p
---         LEFT JOIN pg_catalog.pg_namespace n ON n.oid = p.pronamespace
---         WHERE
---                 pg_catalog.LOWER(n.nspname) = pg_catalog.LOWER('public') AND
---                 pg_catalog.LOWER(p.proname) = pg_catalog.LOWER('ST_AsGeoJson')
---         ORDER BY 1, 2, 3, 4;
-CREATE OR REPLACE FUNCTION _postgis_drop_function_if_needed(
+--  SELECT pg_get_function_arguments('st_intersection(geometry,geometry,float8)'::regprocedure);
+-- Or:
+--  SELECT pg_get_function_arguments(oid) as args
+--  FROM pg_catalog.pg_proc
+--  WHERE proname = 'st_asgeojson'
+CREATE OR REPLACE FUNCTION _postgis_drop_function_by_identity(
 	function_name text,
 	function_arguments text,
 	deprecated_in_version text DEFAULT 'xxx'
@@ -80,3 +80,39 @@ BEGIN
 END;
 $$ LANGUAGE plpgsql;
+CREATE OR REPLACE FUNCTION _postgis_drop_function_by_signature(
+  function_signature text,
+  deprecated_in_version text DEFAULT 'xxx'
+) RETURNS void AS $$
+DECLARE
+	sql text;
+	detail TEXT;
+	newname TEXT;
+	proc RECORD;
+	deprecated_suffix TEXT := '_deprecated_by_postgis_' || deprecated_in_version;
+BEGIN
+	-- Check if the deprecated function exists
+	BEGIN
+		SELECT *
+		FROM pg_catalog.pg_proc
+		WHERE oid = function_signature::regprocedure
+		INTO proc;
+	EXCEPTION
+	WHEN undefined_function THEN
+		RAISE DEBUG 'Deprecated function % does not exist', function_signature;
+		RETURN;
+	END;
+	sql := pg_catalog.format(
+		'ALTER FUNCTION %s RENAME TO %I',
+		proc.oid::regprocedure,
+		proc.proname || deprecated_suffix
+	EXECUTE sql;
+END;
+$$ LANGUAGE plpgsql;
diff --git a/postgis/postgis_before_upgrade.sql b/postgis/postgis_before_upgrade.sql
index f8607f216..0519d5559 100644
--- a/postgis/postgis_before_upgrade.sql
+++ b/postgis/postgis_before_upgrade.sql
@@ -22,7 +22,7 @@
 -- FUNCTION AddGeometryColumn signature dropped
 -- (catalog_name character varying, schema_name character varying, table_name character varying, column_name character varying, new_srid integer, new_type character varying, new_dim integer, use_typmod boolean)
-SELECT _postgis_drop_function_if_needed
+SELECT _postgis_drop_function_by_identity
 	'AddGeometryColumn',
 	'catalog_name character varying, schema_name character varying, table_name character varying, column_name character varying, new_srid integer, new_type character varying, new_dim integer, use_typmod boolean'
@@ -30,7 +30,7 @@ SELECT _postgis_drop_function_if_needed
 -- FUNCTION ST_AsX3D was changed to add versioning for 2.0
 -- (geom geometry, prec integer, options integer)
 	'ST_AsX3D',
 	'geom geometry, prec integer, options integer'
@@ -40,7 +40,7 @@ SELECT _postgis_drop_function_if_needed
 -- It changed the paramenter `new_srid` to `new_srid_in`
 -- (catalogn_name character varying, schema_name character varying, table_name character varying, column_name character varying, new_srid integer)
 -- Dropping it conditionally since the same signature still exists.
 	'UpdateGeometrySRID',
 	'catalogn_name character varying, schema_name character varying, table_name character varying, column_name character varying, new_srid integer'
@@ -84,7 +84,7 @@ $$ ;
 -- FUNCTION ST_AsLatLonText went from multiple signatures to a single one with defaults for 2.2.0
 DROP FUNCTION IF EXISTS ST_AsLatLonText(geometry); -- Does not conflict
 	'ST_AsLatLonText',
 	'geometry, text'
@@ -92,7 +92,7 @@ SELECT _postgis_drop_function_if_needed
 -- FUNCTION ST_LineCrossingDirection changed argument names in 3.0
 -- Was (geom1 geometry, geom2 geometry) and now (line1 geometry, line2 geometry)
 	'ST_LineCrossingDirection',
 	'geom1 geometry, geom2 geometry'
@@ -100,7 +100,7 @@ SELECT _postgis_drop_function_if_needed
 -- FUNCTION _st_linecrossingdirection changed argument names in 3.0
 	'_ST_LineCrossingDirection',
@@ -108,7 +108,7 @@ SELECT _postgis_drop_function_if_needed
 -- FUNCTION ST_AsGeoJson changed argument names
 -- (pretty_print => pretty_bool) in 3.0alpha4
 	'ST_AsGeoJson',
 	$args$r record, geom_column text, maxdecimaldigits integer, pretty_print boolean$args$
@@ -116,7 +116,7 @@ SELECT _postgis_drop_function_if_needed
 -- FUNCTION _st_orderingequals changed argument names in 3.0
 -- Was (GeometryA geometry, GeometryB geometry) and now (geom1 geometry, geom2 geometry)
 	'_st_orderingequals',
 	'GeometryA geometry, GeometryB geometry'
@@ -124,7 +124,7 @@ SELECT _postgis_drop_function_if_needed
 -- FUNCTION st_orderingequals changed argument names in 3.0
 	'st_orderingequals',
commit 49ddd911f69b7843bda7a8c06c44bf3de91f20b5
Date:   Thu Aug 31 22:23:07 2023 +0200
    Allow testing double-upgrades with upgrade-path
diff --git a/regress/run_test.pl b/regress/run_test.pl
index 0b502b6fe..a9cce2a56 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -184,7 +184,7 @@ sub postgis_restore
 if ( $OPT_UPGRADE_PATH )
-  $OPT_UPGRADE = 1; # implied
+  $OPT_UPGRADE = 1 if not $OPT_UPGRADE; # implied
   my @path = split ('--', $OPT_UPGRADE_PATH);
   $OPT_UPGRADE_FROM = $path[0]
     || die "Malformed upgrade path, <from>--<to> expected, $OPT_UPGRADE_PATH given";
Summary of changes:
 postgis/common_after_upgrade.sql   |  3 +-
 postgis/common_before_upgrade.sql  | 60 ++++++++++++++++++++++++++++++--------
 postgis/postgis_before_upgrade.sql | 18 ++++++------
 regress/run_test.pl                |  2 +-
 4 files changed, 60 insertions(+), 23 deletions(-)
hooks/post-receive
