[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-93-g9debf07db
Thu Aug 31 16:07:13 PDT 2023
the project "PostGIS".
       via  9debf07dbfde8bad8d5c11fc6bc9bd45bfff9daa (commit)
       via  7c454b8e0a4eb41af503ee2eb6396c3d7b059f09 (commit)
      from  3a831d5c6ccde943da253e6ca932c483d4179348 (commit)
revisions in full, below.
commit 9debf07dbfde8bad8d5c11fc6bc9bd45bfff9daa
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Sep 1 01:06:54 2023 +0200
    Hash a warning accidentally left in
diff --git a/postgis/common_before_upgrade.sql b/postgis/common_before_upgrade.sql
index f57eaa66b..29b9f59fe 100644
--- a/postgis/common_before_upgrade.sql
+++ b/postgis/common_before_upgrade.sql
@@ -66,7 +66,7 @@ BEGIN
 			matching_function.oid::regprocedure,
 			matching_function.proname || deprecated_suffix
-		RAISE WARNING 'SQL query: %', sql;
+		RAISE DEBUG 'SQL query: %', sql;
 		BEGIN
 			EXECUTE sql;
 		EXCEPTION
commit 7c454b8e0a4eb41af503ee2eb6396c3d7b059f09
Date:   Thu Aug 31 21:55:46 2023 +0200
    Use exact equality for function identity on drop_by_identity
index a6389faef..f57eaa66b 100644
@@ -58,7 +58,7 @@ BEGIN
 	WHERE pronamespace = postgis_namespace
 	AND pg_catalog.LOWER(p.proname) = pg_catalog.LOWER(function_name)
 	AND pg_catalog.pg_function_is_visible(p.oid)
-	AND pg_catalog.LOWER(pg_catalog.pg_get_function_identity_arguments(p.oid)) ~ pg_catalog.LOWER(function_arguments)
+	AND pg_catalog.LOWER(pg_catalog.pg_get_function_identity_arguments(p.oid)) = pg_catalog.LOWER(function_arguments)
 	INTO matching_function;
 	IF matching_function.oid IS NOT NULL THEN
Summary of changes:
 postgis/common_before_upgrade.sql | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
