[SCM] PostGIS branch master updated. 3.4.0rc1-831-g0cd1efc17
Wed Dec 6 18:23:55 PST 2023
the project "PostGIS".
       via  0cd1efc17b48172863c816e3b71365d4cdbad272 (commit)
      from  8f77e8a6b2bc26d8cb77daa221f6edda20aa3f04 (commit)
revisions in full, below.
commit 0cd1efc17b48172863c816e3b71365d4cdbad272
Author: Zuochenwei <zuochenwei5 at gmail.com>
Date:   Thu Dec 7 01:08:37 2023 +0000
    Translated PostGIS Manual using Weblate (Chinese (Simplified))
    Currently translated at 100.0% (5647 of 5647 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/zh_Hans/
diff --git a/doc/po/zh_Hans/postgis-manual.po b/doc/po/zh_Hans/postgis-manual.po
index 8e51c049a..8967444ba 100644
--- a/doc/po/zh_Hans/postgis-manual.po
+++ b/doc/po/zh_Hans/postgis-manual.po
@@ -6,7 +6,7 @@ msgstr ""
 "Project-Id-Version: postgis 3.5\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2023-11-29 04:00+0000\n"
-"PO-Revision-Date: 2023-11-28 12:23+0000\n"
+"PO-Revision-Date: 2023-12-07 02:23+0000\n"
 "Last-Translator: Zuochenwei <zuochenwei5 at gmail.com>\n"
 "Language-Team: Chinese (Simplified) <https://weblate.osgeo.org/projects/"
 "postgis/postgis-manual/zh_Hans/>\n"
@@ -9571,7 +9571,7 @@ msgstr "Jan Katins"
 #. Tag: member
 #, no-c-format
 msgid "Jan Tojnar"
-msgstr ""
+msgstr "Jan Tojnar"
 #. Tag: member
 #, no-c-format
@@ -15604,7 +15604,7 @@ msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid "Returns a line extended forwards and backwards by specified distances."
-msgstr ""
+msgstr "返回一条线,向前和向后延伸指定的距离。"
 #. Tag: para
 #, no-c-format
@@ -15615,6 +15615,9 @@ msgid ""
 "point(s) is determined by the first (and last) two distinct points of the "
 "line. Duplicate points are ignored."
 msgstr ""
+"返回一条线,通过在给定的距离处添加新的起始点(和结束点),向前和向后延伸。距"
+"离为零不会添加点。只允许非负距离。所添加点的方向由线的第一个(和最后一个)不"
+"同的两个点确定。重复的点将被忽略。"
 #. Tag: title
 #, no-c-format
@@ -15624,7 +15627,7 @@ msgstr "例如:将一条线向前延伸5个单位,向后延伸6个单位"
 #. Tag: para
 #, no-c-format
 msgid ", <xref linkend=\"ST_LocateAlong\"/>, <xref linkend=\"ST_Project\"/>"
-msgstr ""
+msgstr ", <xref linkend=\"ST_LocateAlong\"/>, <xref linkend=\"ST_Project\"/>"
 #. Tag: refpurpose
 #, no-c-format
@@ -18464,6 +18467,8 @@ msgid ""
 ", <xref linkend=\"ST_LineExtend\"/>, <xref linkend=\"ST_LineInterpolatePoint"
 "\"/>, <xref linkend=\"ST_LineMerge\"/>"
 msgstr ""
+", <xref linkend=\"ST_LineExtend\"/>, <xref linkend=\"ST_LineInterpolatePoint"
+"\"/>, <xref linkend=\"ST_LineMerge\"/>"
 #. Tag: refpurpose
 #, no-c-format
@@ -22174,6 +22179,11 @@ msgid ""
 "any columns other than the geometry, including any potential keys, will just "
 "end up inside the feature’s \"properties\" member."
 msgstr ""
+"<varname>id_column</varname> 参数用于设置返回的 GeoJSON 要素的 \"id\" 成员。"
+"根据 GeoJSON "
+"RFC,应该在要素具有常用标识符(例如主键)时使用此参数。当未指定时,"
+"生成的要素将不会有 \"id\" 成员,除了几何信息之外的任何列,包括任何可能的键,"
+"都将最终位于要素的 \"properties\" 成员内。"
 #. Tag: para
 #, no-c-format
@@ -22240,7 +22250,7 @@ msgstr "更改:3.0.0 输出 SRID(如果不是 EPSG:4326)。"
 #. Tag: para
 #, no-c-format
 msgid "Changed: 3.5.0 allow specifying the column containing the feature id"
-msgstr ""
+msgstr "更改:3.5.0 允许指定包含要素 ID 的列"
 #. Tag: para
 #, no-c-format
Summary of changes:
 doc/po/zh_Hans/postgis-manual.po | 20 +++++++++++++++-----
 1 file changed, 15 insertions(+), 5 deletions(-)
hooks/post-receive
