[PostGIS] #5640: ST_Covers missed one of the pairs
PostGIS trac at osgeo.org
Thu Dec 7 02:21:42 PST 2023
 Reporter:  Wenjing  |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 3.4.2
Component:  postgis  |    Version:  3.4.x
 Keywords:           |
 Consider the following statements:
 DROP TABLE IF EXISTS origin;
 CREATE TABLE origin (id int, geom geometry, valid boolean, gRelate int);
 INSERT INTO origin (id, geom) VALUES (1, ST_LineFromText('LINESTRING(75
 15,55 43)',0));
 INSERT INTO origin (id, geom) VALUES (2, ST_LineFromText('LINESTRING(75
 15,55 43)',0));
 INSERT INTO origin (id, geom) VALUES (3,
 ST_GeomFromText('GEOMETRYCOLLECTION(MULTIPOLYGON EMPTY,LINESTRING(75 15,55
 43))',0));
 SELECT a1.id, a2.id         FROM origin As a1          JOIN origin As a2
 ON ST_Covers(a1.geom, a2.geom)          WHERE   a1.id <> a2.id;
 -- actual {1,2; 2,1; 3,1; 3,2}; expected {1,2; 2,1; 3,1; 3,2; 1,3; 2,3}
 The 1st geometry covers the 3rd one, because each point in 3st geometry
 lies inside 1st one, according to the definition  of ST_Covers
 > Returns true if every point in Geometry/Geography B lies inside (i.e.
 intersects the interior or boundary of) Geometry/Geography A.
 and the following statement result:
 SELECT ST_Covers(a1.geom, a2.geom) FROM origin As a1, origin As a2 WHERE
 a1.id = 1 and a2.id = 3;
 -- result{t}
 However, PostGis missed the pairs of 1,3 and 2,3.
 The version is the newest on
 [GitHub](https://trac.osgeo.org/postgis/wiki/GitHub):
 POSTGIS="3.5.0dev 3.4.0rc1-818-g6c2e935b6" [EXTENSION] PGSQL="170"
 GEOS="3.13.0dev-CAPI-1.18.0" PROJ="8.2.1
 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org/
 USER_WRITABLE_DIRECTORY=/tmp/proj DATABASE_PATH=/usr/
 share/proj/proj.db" LIBXML="2.9.13"
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5640>
