[PostGIS] #5645: Code blocks => being replaced with = >
PostGIS trac at osgeo.org
Fri Dec 15 15:41:01 PST 2023
 Reporter:  robe           |      Owner:  robe
     Type:  defect         |     Status:  new
 Priority:  medium         |  Milestone:  PostGIS 3.5.0
Component:  documentation  |    Version:  3.4.x
 Keywords:                 |
 As noted in https://lists.osgeo.org/pipermail/postgis-
 users/2023-December/046287.html
 Code blocks with =>  are being converted to = > in the translated docs.
 code blocks don't make it to .pot files I don't think, so I suspect this
 is totally something in our conversion from po to xml
 Case in point is - ST_Clip where I used => touched
 https://postgis.net/docs/manual-dev/zh_Hans/RT_ST_Clip.html
 So I could skip over other default options
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5645>
