[PostGIS] #5645: Code blocks => being replaced with = >
PostGIS trac at osgeo.org
Sat Dec 16 01:52:01 PST 2023
  Reporter:  robe           |      Owner:  robe
      Type:  defect         |     Status:  new
  Priority:  medium         |  Milestone:  PostGIS 3.5.0
 Component:  documentation  |    Version:  3.4.x
Resolution:                 |   Keywords:
Description changed by robe:
Old description:
> As noted in https://lists.osgeo.org/pipermail/postgis-
> users/2023-December/046287.html
> Code blocks with =>  are being converted to = > in the translated docs.
> code blocks don't make it to .pot files I don't think, so I suspect this
> is totally something in our conversion from po to xml
> Case in point is - ST_Clip where I used => touched
> https://postgis.net/docs/manual-dev/zh_Hans/RT_ST_Clip.html
> So I could skip over other default options
New description:
 Code blocks with
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5645#comment:1>
