[postgis-tickets] [PostGIS] #5333: Use proj_context_set_enable_network() to allow user-level toggle of proj network?
PostGIS trac at osgeo.org
Wed Feb 8 00:08:17 PST 2023
network?
  Reporter:  pramsey      |      Owner:  pramsey
      Type:  enhancement  |     Status:  new
  Priority:  medium       |  Milestone:  PostGIS 3.4.0
 Component:  postgis      |    Version:  master
Resolution:               |   Keywords:
Comment (by robe):
 I assume this wouldn't work if proj wasn't built with curl support right?
 So if not built with curl support, what would happen if its set to true on
 the GUC?
 Would it error or allow it and we just wouldn't do anything?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5333#comment:1>
