[postgis-tickets] [PostGIS] #5320: ST_SimplifyPreserveTopology crashes with infinity coordinates
PostGIS trac at osgeo.org
Wed Feb 8 13:57:18 PST 2023
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  assigned
  Priority:  blocker  |  Milestone:  PostGIS 3.0.9
 Component:  postgis  |    Version:  master
Resolution:           |   Keywords:
Description changed by robe:
Old description:
> Same issue as #5318, #5317, #5315
> SELECT ST_SimplifyPreserveTopology(foo1.the_geom, 20.1)  As result
>                                                         FROM ((SELECT
> '0106000020E61000000100000001030000000100000005000000000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F'::geometry
> AS the_geom ) ) As foo1 ;
New description:
 Same issue as #5318, #5319, #5315
                                                         FROM ((SELECT
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5320#comment:2>
