[postgis-tickets] [PostGIS] #5320: ST_SimplifyPreserveTopology crashes with infinity coordinates
PostGIS trac at osgeo.org
Wed Feb 8 15:05:14 PST 2023
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  assigned
  Priority:  blocker  |  Milestone:  PostGIS 3.0.9
 Component:  postgis  |    Version:  master
Resolution:           |   Keywords:
Comment (by pramsey):
 The question, as always for these kinds of things, is where to put the
 fix. We could put a big "no infinites" test at the PostGIS level, before
 calling into GEOS. Or we could put a test in Quadtree::Root to throw an
 exception in the case of infinite envelopes, since the Quadtree code is
 definitely not infinite-safe. I lean towards the latter as the "correct"
 fix, but it means this won't be fixed "in postgis", but in a patch release
 of GEOS.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5320#comment:3>
