[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-593-g7505ad7a6
Fri Feb 10 01:15:22 PST 2023
the project "PostGIS".
       via  7505ad7a6de9fd961ea0a3ead1e4861a327ce4c2 (commit)
      from  4bcdc968534100cb8b316c166f2513ffa09a03e9 (commit)
revisions in full, below.
commit 7505ad7a6de9fd961ea0a3ead1e4861a327ce4c2
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Feb 10 10:15:10 2023 +0100
    Drop dependency on cpan module File::Which
diff --git a/regress/run_test.pl b/regress/run_test.pl
index 12b3e889c..d769fefee 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -16,7 +16,6 @@
 use File::Basename;
 use File::Temp 'tempdir';
 use Time::HiRes qw(time);
-use File::Which;
 use File::Copy;
 use File::Path;
 use Cwd 'abs_path';
@@ -118,17 +117,20 @@ if ( @ARGV < 1 )
 sub findOrDie
     my $exec = shift;
-    my $path = which $exec;
 	printf "Checking for %s ... ", $exec;
-    if ( defined($path) ) {
-		print "found ($path)\n";
+    #my $path = which $exec;
+    foreach my $d ( split /:/, $ENV{PATH} )
+        my $path = $d . '/' . $exec;
+        if ( -x $path ) {
+		    print "found ($path)\n";
+            return $path;
-    else {
-		print "failed\n";
-		print STDERR "Unable to find $exec executable.\n";
-		print STDERR "PATH is " . $ENV{"PATH"} . "\n";
-		die "HINT: use POSTGIS_TOP_BUILD_DIR env or --build-dir switch the specify top build dir.\n";
+    print "failed\n";
+    print STDERR "Unable to find $exec executable.\n";
+    print STDERR "PATH is " . $ENV{"PATH"} . "\n";
+    die "HINT: use POSTGIS_TOP_BUILD_DIR env or --build-dir switch the specify top build dir.\n";
 # Prepend scripts' build dirs to path
Summary of changes:
 regress/run_test.pl | 22 ++++++++++++----------
 1 file changed, 12 insertions(+), 10 deletions(-)
hooks/post-receive
