[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-594-gb669712b3
Fri Feb 10 03:24:15 PST 2023
the project "PostGIS".
       via  b669712b3ea8df41e179316bd4ce76210a001e32 (commit)
      from  7505ad7a6de9fd961ea0a3ead1e4861a327ce4c2 (commit)
revisions in full, below.
commit b669712b3ea8df41e179316bd4ce76210a001e32
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Feb 10 12:23:59 2023 +0100
    Only check for loaders if needed
diff --git a/regress/run_test.pl b/regress/run_test.pl
index d769fefee..b0c1ff6f1 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -88,7 +88,7 @@ our $VERBOSE = 0;
 our $OPT_SCHEMA = 'public';
 GetOptions (
-	'verbose' => \$VERBOSE,
+	'verbose+' => \$VERBOSE,
 	'clean' => \$OPT_CLEAN,
 	'nodrop' => \$OPT_NODROP,
 	'upgrade' => \$OPT_UPGRADE,
@@ -117,17 +117,20 @@ if ( @ARGV < 1 )
 sub findOrDie
     my $exec = shift;
-	printf "Checking for %s ... ", $exec;
-    #my $path = which $exec;
+    my $verbose = shift;
+    printf "Checking for %s ... ", $exec if $verbose;
     foreach my $d ( split /:/, $ENV{PATH} )
         my $path = $d . '/' . $exec;
         if ( -x $path ) {
-		    print "found ($path)\n";
-            return $path;
+            if ( $verbose ) {
+                print "found";
+                print " ($path)" if $verbose gt 1;
+                print "\n";
+            return $path
-    print "failed\n";
     print STDERR "Unable to find $exec executable.\n";
     print STDERR "PATH is " . $ENV{"PATH"} . "\n";
     die "HINT: use POSTGIS_TOP_BUILD_DIR env or --build-dir switch the specify top build dir.\n";
@@ -137,9 +140,26 @@ sub findOrDie
 # TODO: make this conditional ?
 $ENV{PATH} = $TOP_BUILDDIR . '/loader:' . $TOP_BUILDDIR .  '/raster/loader:' . $ENV{PATH};
-our $SHP2PGSQL = findOrDie 'shp2pgsql';
-our $PGSQL2SHP = findOrDie 'pgsql2shp';
-our $RASTER2PGSQL = findOrDie 'raster2pgsql' if ( $OPT_WITH_RASTER );
+our $SHP2PGSQL;
+sub shp2pgsql
+    $SHP2PGSQL = findOrDie 'shp2pgsql', @_ unless defined($SHP2PGSQL);
+    return $SHP2PGSQL;
+our $PGSQL2SHP;
+sub pgsql2shp
+    $PGSQL2SHP = findOrDie 'pgsql2shp', @_ unless defined($PGSQL2SHP);
+    return $PGSQL2SHP;
+our $RASTER2PGSQL;
+sub raster2pgsql
+    $RASTER2PGSQL = findOrDie 'raster2pgsql', @_ unless defined($RASTER2PGSQL);
+    return $RASTER2PGSQL;
 if ( $OPT_UPGRADE_PATH )
@@ -194,6 +214,25 @@ my $OBJ_COUNT_POST = 0;
 # Set up the temporary directory
+# Pre-flight to check if we need
+# to find shp2pgsql/pgsql2shp/raster2pgsql
+foreach $TEST (@ARGV)
+    if ( -r "${TEST}.dbf" )
+        shp2pgsql($VERBOSE);
+        pgsql2shp($VERBOSE);
+    elsif ( -r "${TEST}.tif" )
+        raster2pgsql($VERBOSE);
+# Set up the temporary directory
 my $TMPDIR;
 if ( $ENV{'PGIS_REG_TMPDIR'} )
@@ -214,7 +253,7 @@ mkpath $TMPDIR; # make sure tmp dir exists
 my $REGRESS_LOG = "${TMPDIR}/regress_log";
 # Report
-print "TMPDIR is $TMPDIR\n";
+print "TMPDIR is $TMPDIR\n" if $VERBOSE gt 1;
 # Prepare the database
@@ -353,7 +392,6 @@ if ( $OPT_DUMPRESTORE )
     die unless dump_restore();
 # Report PostGIS environment
@@ -887,7 +925,7 @@ sub run_loader_and_check_output
 		show_progress();
 		# Produce the output SQL file.
-		$cmd = "$SHP2PGSQL $loader_options -g the_geom ${TEST}.shp $tblname > $outfile 2> $errfile";
+		$cmd = shp2pgsql() . " $loader_options -g the_geom ${TEST}.shp $tblname > $outfile 2> $errfile";
 		$rv = system($cmd);
 		if ( $rv )
@@ -953,7 +991,7 @@ sub run_dumper_and_check_output
 	if ( $run_always || -r $expected_shp_file )
 		show_progress();
-		$cmd = "${PGSQL2SHP} -f ${TMPDIR}/dumper $DB $tblname > $errfile 2>&1";
+		$cmd = pgsql2shp() . " -f ${TMPDIR}/dumper $DB $tblname > $errfile 2>&1";
 		$rv = system($cmd);
 		if ( $rv )
@@ -1020,7 +1058,7 @@ sub run_raster_loader_and_check_output
 		show_progress();
-		$cmd = "$RASTER2PGSQL $loader_options $raster_file $tblname > $outfile 2> $errfile";
+		$cmd = raster2pgsql() . " $loader_options $raster_file $tblname > $outfile 2> $errfile";
 		$rv = system($cmd);
 		if ( $rv )
@@ -1190,7 +1228,7 @@ sub run_dumper_test
   chomp(@dumplines);
   my $dumpstring = shift @dumplines;
   @dumplines = map { local $_ = $_; s/{regdir}/$REGDIR/; $_ } @dumplines;
-  my @cmd = ("${PGSQL2SHP}", "-f", ${shpfile});
+  my @cmd = ( pgsql2shp(), "-f", ${shpfile});
   push @cmd, @dumplines;
   push @cmd, ${DB};
   push @cmd, $dumpstring;
Summary of changes:
 regress/run_test.pl | 68 +++++++++++++++++++++++++++++++++++++++++------------
 1 file changed, 53 insertions(+), 15 deletions(-)
hooks/post-receive
