[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-615-gb44b8a9a0
Wed Feb 15 13:44:56 PST 2023
the project "PostGIS".
       via  b44b8a9a015f05db7ffefcec21b9cd23fbd7108d (commit)
      from  d53dea68a838959637ead34d233840fcba5cb5ce (commit)
revisions in full, below.
commit b44b8a9a015f05db7ffefcec21b9cd23fbd7108d
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Wed Feb 15 13:44:46 2023 -0800
    Standardize doc use_spheroid param
diff --git a/doc/reference_processing.xml b/doc/reference_processing.xml
index 4ec658043..9f519bba2 100644
--- a/doc/reference_processing.xml
+++ b/doc/reference_processing.xml
@@ -481,7 +481,7 @@ FROM (SELECT
                 <paramdef><type>geography </type>
                 <parameter>g1</parameter></paramdef>
                 <paramdef choice="opt"><type>boolean </type>
-                <parameter>use_spheroid=true</parameter></paramdef>
+                <parameter>use_spheroid = true</parameter></paramdef>
     </funcprototype>
       </funcsynopsis>
diff --git a/doc/reference_relationship.xml b/doc/reference_relationship.xml
index 799b6b05e..8192b9e4d 100644
--- a/doc/reference_relationship.xml
+++ b/doc/reference_relationship.xml
@@ -2176,8 +2176,8 @@ ST_DWithin(
     (have the same SRID).</para>
     <para>For <type>geography</type>: units are in meters and distance measurement
-    defaults to <varname>use_spheroid</varname>=true.
-        For faster evaluation use <varname>use_spheroid</varname>=false to measure on the sphere.
+    defaults to <varname>use_spheroid = true</varname>.
+    For faster evaluation use <varname>use_spheroid = false</varname> to measure on the sphere.
     </para>
     <note><para>Use <xref linkend="ST_3DDWithin"/> for 3D geometries.</para></note>
Summary of changes:
 doc/reference_processing.xml   | 2 +-
 doc/reference_relationship.xml | 4 ++--
 2 files changed, 3 insertions(+), 3 deletions(-)
hooks/post-receive
