[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-616-gb347a9a96
Wed Feb 15 14:03:45 PST 2023
the project "PostGIS".
       via  b347a9a965f2a3efdf50485ec0947aa843381fe6 (commit)
      from  b44b8a9a015f05db7ffefcec21b9cd23fbd7108d (commit)
revisions in full, below.
commit b347a9a965f2a3efdf50485ec0947aa843381fe6
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Wed Feb 15 14:03:42 2023 -0800
    Standardize doc use_spheroid formatting
diff --git a/doc/reference_measure.xml b/doc/reference_measure.xml
index a0fdf7a92..669ef49b6 100644
--- a/doc/reference_measure.xml
+++ b/doc/reference_measure.xml
@@ -26,7 +26,7 @@
 			<funcprototype>
 			  <funcdef>float <function>ST_Area</function></funcdef>
 				<paramdef><type>geography </type><parameter>geog</parameter></paramdef>
-				<paramdef choice="opt"><type>boolean </type><parameter>use_spheroid=true</parameter></paramdef>
+				<paramdef choice="opt"><type>boolean </type><parameter>use_spheroid = true</parameter></paramdef>
 			</funcprototype>
 		  </funcsynopsis>
 		</refsynopsisdiv>
@@ -493,7 +493,7 @@ SELECT ST_AsEWKT(ST_3DClosestPoint(line,pt)) AS cp3d_line_pt,
 			<parameter>geog2</parameter></paramdef>
-			<parameter>use_spheroid=true</parameter></paramdef>
+			<parameter>use_spheroid = true</parameter></paramdef>
 		  </funcprototype>
 		</funcsynopsis>
@@ -989,7 +989,7 @@ SELECT DISTINCT ON (buildings.gid) buildings.gid, parcels.parcel_id
 			<funcprototype>
 			  <funcdef>float <function>ST_Length</function></funcdef>
 			</funcprototype>
 		  </funcsynopsis>
 		</refsynopsisdiv>
@@ -1002,7 +1002,7 @@ SELECT DISTINCT ON (buildings.gid) buildings.gid, parcels.parcel_id
 				spatial reference system of the geometry.</para>
 			<para>For geography types: computation is performed using the inverse geodesic calculation. Units of length are in meters.
 				If PostGIS is compiled with PROJ version 4.8.0 or later, the spheroid is specified by the SRID, otherwise it is exclusive to WGS84.
-				If <varname>use_spheroid=false</varname>, then the calculation is based on a sphere instead of a spheroid.
+				If <varname>use_spheroid = false</varname>, then the calculation is based on a sphere instead of a spheroid.
 				</para>
 			<para>Currently for geometry this is an alias for ST_Length2D, but this may change to support higher dimensions.</para>
@@ -1699,7 +1699,7 @@ LINESTRING(0.5 0.00032,0.5 0)
 			<funcprototype>
 			  <funcdef>float <function>ST_Perimeter</function></funcdef>
 			</funcprototype>
 		  </funcsynopsis>
 		</refsynopsisdiv>
@@ -1711,7 +1711,7 @@ LINESTRING(0.5 0.00032,0.5 0)
 			<para>For geography types, the calculations are performed using the inverse geodesic problem, where perimeter units are in meters.
-				If <varname>use_spheroid=false</varname>, then calculations will approximate a sphere instead of a spheroid.</para>
+				If <varname>use_spheroid = false</varname>, then calculations will approximate a sphere instead of a spheroid.</para>
 			<para>Currently this is an alias for ST_Perimeter2D, but this may change to support higher dimensions.</para>
Summary of changes:
 doc/reference_measure.xml | 12 ++++++------
 1 file changed, 6 insertions(+), 6 deletions(-)
hooks/post-receive
