[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-617-gd157731b4
    git at osgeo.org
    git at osgeo.org
    Wed Feb 15 14:16:58 PST 2023
the project "PostGIS".
       via  d157731b4df9b339a7a07054c59206fa3b74a72d (commit)
      from  b347a9a965f2a3efdf50485ec0947aa843381fe6 (commit)
revisions in full, below.
commit d157731b4df9b339a7a07054c59206fa3b74a72d
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Wed Feb 15 14:16:56 2023 -0800
    Improve doc for ST_Segmentize
diff --git a/doc/html/image_src/Makefile.in b/doc/html/image_src/Makefile.in
index aa0e7c6ed..d6d283dde 100644
--- a/doc/html/image_src/Makefile.in
+++ b/doc/html/image_src/Makefile.in
@@ -154,6 +154,7 @@ IMAGES= \
 	../images/st_pointonsurface03.png \
 	../images/st_pointonsurface04.png \
 	../images/st_triangulatepolygon01.png \
+	../images/st_segmentize01.png \
 	../images/st_sharedpaths01.png \
 	../images/st_sharedpaths02.png \
 	../images/st_shortestline01.png \
diff --git a/doc/html/image_src/st_segmentize01.wkt b/doc/html/image_src/st_segmentize01.wkt
new file mode 100644
index 000000000..6feb081c9
--- /dev/null
+++ b/doc/html/image_src/st_segmentize01.wkt
@@ -0,0 +1,2 @@
+ArgA;LINESTRING (10 10, 190 190)
+Result-endpoints;LINESTRING (10 10, 23 35, 36 60, 51 85, 67 110, 87 133, 113 155, 146 175, 190 190)
diff --git a/doc/reference_editor.xml b/doc/reference_editor.xml
index de7d61218..0d059bc33 100644
--- a/doc/reference_editor.xml
+++ b/doc/reference_editor.xml
@@ -1645,7 +1645,7 @@ LINESTRING(1 2,1 10) | LINESTRING(1 10,1 2)
 		<refnamediv>
 			<refname>ST_Segmentize</refname>
-			<refpurpose>Return a modified geometry/geography having no segment longer than the
+			<refpurpose>Returns a modified geometry/geography having no segment longer than a
 			given distance.</refpurpose>
 		</refnamediv>
@@ -1667,40 +1667,81 @@ LINESTRING(1 2,1 10) | LINESTRING(1 10,1 2)
 		<refsection>
 			<title>Description</title>
-			<para>Returns a modified geometry having no segment longer than the
-			given <varname>max_segment_length</varname>.  Distance computation is performed in 2d
-			only. For geometry, length units are in units of spatial reference.  For geography, units are in meters.</para>
+			<para>Returns a modified geometry/geography having no segment longer than
+			<varname>max_segment_length</varname>.
+            Length is computed in 2D.
+            Segments are always split into equal-length subsegments.
+            </para>
+            <itemizedlist>
+                <listitem><para>For geometry, the maximum length is in the units of the spatial reference system.
+                </para></listitem>
+                <listitem><para>For geography, the maximum length is in meters.
+                Distances are computed on the sphere.
+                Added vertices are created along the spherical great-circle arcs
+                defined by segment endpoints.
+            </itemizedlist>
+			<note><para>This only shortens long segments.
+            It does not lengthen segments shorter than the maximum length.
+            </para></note>
+            <warning><para>For inputs containing long segments,
+            specifying a relatively short <varname>max_segment_length</varname>
+            can cause a very large number of vertices to be added.
+            This can happen unintentionally if the argument is specified accidentally as a number of segments,
+            rather than a maximum length.
+            </para></warning>
 			<para>Availability: 1.2.2</para>
-			<para>Enhanced: 3.0.0 Segmentize geometry now uses equal length segments</para>
-			<para>Enhanced: 2.3.0 Segmentize geography now uses equal length segments</para>
+			<para>Enhanced: 3.0.0 Segmentize geometry now produces equal-length subsegments</para>
+			<para>Enhanced: 2.3.0 Segmentize geography now produces equal-length subsegments</para>
 			<para>Enhanced: 2.1.0 support for geography was introduced.</para>
-			<para>Changed: 2.1.0 As a result of the introduction of geography support: The construct <code>SELECT ST_Segmentize('LINESTRING(1 2, 3 4)',0.5);</code> will result in ambiguous function error.  You need to have properly typed object e.g. a geometry/geography column, use ST_GeomFromText, ST_GeogFromText or
-				<code>SELECT ST_Segmentize('LINESTRING(1 2, 3 4)'::geometry,0.5);</code></para>
-			<note><para>This will only increase segments.  It will not lengthen segments shorter than
-			max length</para></note>
+			<para>Changed: 2.1.0 As a result of the introduction of geography support,
+            the usage <code>ST_Segmentize('LINESTRING(1 2, 3 4)', 0.5)</code> causes an ambiguous function error.
+            The input needs to be properly typed as a geometry or geography.
+            Use ST_GeomFromText, ST_GeogFromText or a cast to the required type
+			(e.g. <code>ST_Segmentize('LINESTRING(1 2, 3 4)'::geometry, 0.5) )</code></para>
 		</refsection>
 		<refsection>
 			<title>Examples</title>
+            <para>Segmentizing a line.  Long segments are split evenly, and short segments are not split.</para>
 			<programlisting>SELECT ST_AsText(ST_Segmentize(
-ST_GeomFromText('MULTILINESTRING((-29 -27,-30 -29.7,-36 -31,-45 -33),(-45 -33,-46 -32))')
-		,5)
-st_astext
-MULTILINESTRING((-29 -27,-30 -29.7,-34.886615700134 -30.758766735029,-36 -31,
--40.8809353009198 -32.0846522890933,-45 -33),
-(-45 -33,-46 -32))
-(1 row)
+    'MULTILINESTRING((0 0, 0 1, 0 9),(1 10, 1 18))'::geometry,
+	5 ) );
+MULTILINESTRING((0 0,0 1,0 5,0 9),(1 10,1 14,1 18))
+</programlisting>
-SELECT ST_AsText(ST_Segmentize(ST_GeomFromText('POLYGON((-29 28, -30 40, -29 28))'),10));
-st_astext
-POLYGON((-29 28,-29.8304547985374 37.9654575824488,-30 40,-29.1695452014626 30.0345424175512,-29 28))
-(1 row)
+            <para>Segmentizing a polygon:</para>
+<programlisting>
+SELECT ST_AsText(
+        ST_Segmentize(('POLYGON((0 0, 0 8, 30 0, 0 0))'::geometry), 10));
+POLYGON((0 0,0 8,7.5 6,15 4,22.5 2,30 0,20 0,10 0,0 0))
+</programlisting>
+            <para>Segmentizing a geographic line, using a maximum segment length of 3000 kilometers.
+            Vertices are added along the great-circle arc connecting the endpoints.
+            </para>
+<programlisting>
+SELECT ST_AsText(
+        ST_Segmentize(('LINESTRING (0 0, 60 60)'::geography), 2000000));
+LINESTRING(0 0,4.252632294621186 8.43596525986862,8.69579947419404 16.824093489701564,13.550465473227048 25.107950473646188,19.1066053508691 33.21091076089908,25.779290201459894 41.01711439406505,34.188839517966954 48.337222885886,45.238153936612264 54.84733442373889,60 60)
+</programlisting>
+			<informalfigure>
+			  <mediaobject>
+				<imageobject>
+				  <imagedata fileref="images/st_segmentize01.png" />
+				</imageobject>
+				<caption><para>A geographic line segmentized along a great circle arc</para></caption>
+			  </mediaobject>
+			</informalfigure>
-			</programlisting>
 		</refsection>
 		<refsection>
 			<title>See Also</title>
Summary of changes:
 doc/html/image_src/Makefile.in         |  1 +
 doc/html/image_src/st_segmentize01.wkt |  2 +
 doc/reference_editor.xml               | 91 ++++++++++++++++++++++++----------
 3 files changed, 69 insertions(+), 25 deletions(-)
 create mode 100644 doc/html/image_src/st_segmentize01.wkt
hooks/post-receive
