[postgis-tickets] [PostGIS] #5341: debbie failing on raster upgrade from 3.2 to 3.4
PostGIS trac at osgeo.org
Fri Feb 17 15:25:01 PST 2023
 Reporter:  robe     |      Owner:  robe
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 3.4.0
Component:  raster   |    Version:  master
 Keywords:           |
 Might be related to #5338
 https://debbie.postgis.net/job/PostGIS_Regress/24158/consoleFull
 07:15:14 psql:../../../raster/test/regress/hooks/hook-before-upgrade-
 raster.sql:33: NOTICE:  Adding coverage tile constraint required for
 regular blocking
 raster.sql:33: NOTICE:  Unable to create coverage raster. Cannot add
 coverage tile constraint: column "sqlerrm" does not exist (42703)
 raster.sql:33: WARNING:  Unable to add constraint: 'regular_blocking'.
 Skipping
 raster.sql:33: ERROR:  None of the constraints specified could be added.
 Is the schema name, table name or column name incorrect?
 07:15:14 CONTEXT:  PL/pgSQL function
 addrasterconstraints(name,name,name,text[]) line 119 at RAISE
 07:15:14
 07:15:14 make: *** [../../../regress/runtest.mk:24: check-regress] Error 3
 07:15:14 make: Leaving directory
 '/var/lib/jenkins/workspace/postgis/branches/3.4/raster/test/regress'
 07:15:14 FAIL: postgis_raster script-based upgrade unpackaged3.2--:auto
 07:15:14 Testing postgis_raster script-based upgrade unpackaged3.3--:auto
 07:15:14 make: Entering directory
 07:15:14 RUNTESTFLAGS: -v --upgrade-path=unpackaged3.3--:auto -v --raster
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5341>
