[postgis-tickets] [PostGIS] #5341: debbie failing on raster upgrade from 3.2 to 3.4
PostGIS trac at osgeo.org
Fri Feb 17 15:53:02 PST 2023
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.4.0
 Component:  raster   |    Version:  master
Resolution:           |   Keywords:
Comment (by robe):
 What's interesting is woodie is doing the same upgrade tests and is not
 failing.
 So perhaps something wrong with my backports to older versions.
 Only difference in theory between woodie's
 oading unpackaged components from
 /usr/share/postgresql/15/contrib/postgis-3.3
 1349s
 7138
 Loading PostGIS into 'postgis_reg'
 1349s
 7139
 Upgrading from postgis 3.3.2
 1350s
 7140
 Running before-upgrade-script
 /woodpecker/src/git.osgeo.org/gitea/postgis/postgis/regress/hooks/hook-
 before-upgrade.sql
 1350s
 7141
 Upgrading PostGIS in 'postgis_reg'
 is that debbie would be upgrading from a not yet released version of
 postgis 3.3 which might have the new patch.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5341#comment:1>
