[postgis-tickets] [SCM] PostGIS branch stable-3.3 updated. 3.3.2-28-gf23f6b7d9
Mon Feb 20 02:05:50 PST 2023
the project "PostGIS".
The branch, stable-3.3 has been updated
       via  f23f6b7d9486b1583b7414d40b68f6438dc23dee (commit)
      from  01d1bf3c2ec6a01a324da951da8a825c84e4097f (commit)
revisions in full, below.
commit f23f6b7d9486b1583b7414d40b68f6438dc23dee
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Feb 20 01:38:12 2023 +0100
    Mark topology.topology_id_seq as a user data
    References #5344 in stable-3.3 branch (3.3.3dev)
diff --git a/NEWS b/NEWS
index 1806dea92..460f196d9 100644
--- a/NEWS
+++ b/NEWS
@@ -17,6 +17,7 @@ YYYY/MM/DD
            enforce_coverage_tile_rast constraint (Regina Obe)
   - #5315, #5318, #5319, #5320, #5342 crashes on infinite coordinates
           (Regina Obe, Paul Ramsey)
+  - #5344, Include topology id sequence state in dumps (Sandro Santilli)
 PostGIS 3.3.2
diff --git a/extensions/postgis_topology/sql_bits/mark_editable_objects.sql.in b/extensions/postgis_topology/sql_bits/mark_editable_objects.sql.in
index ffc5c477f..b25e5b713 100644
--- a/extensions/postgis_topology/sql_bits/mark_editable_objects.sql.in
+++ b/extensions/postgis_topology/sql_bits/mark_editable_objects.sql.in
@@ -1,2 +1,3 @@
+SELECT pg_catalog.pg_extension_config_dump('topology.topology_id_seq', '');
 SELECT pg_catalog.pg_extension_config_dump('topology.topology', '');
 SELECT pg_catalog.pg_extension_config_dump('topology.layer', '');
Summary of changes:
 NEWS                                                              | 1 +
 extensions/postgis_topology/sql_bits/mark_editable_objects.sql.in | 1 +
 2 files changed, 2 insertions(+)
hooks/post-receive
