[postgis-tickets] [SCM] PostGIS branch stable-3.2 updated. 3.2.4-10-g3ce97f49f
Mon Feb 20 02:47:59 PST 2023
the project "PostGIS".
The branch, stable-3.2 has been updated
       via  3ce97f49f2d41a58b9e210c3378245e0d2421672 (commit)
      from  4e592fc41217c50ed0e56fc4d1e1dde2f1cacb7f (commit)
revisions in full, below.
commit 3ce97f49f2d41a58b9e210c3378245e0d2421672
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Feb 20 01:38:12 2023 +0100
    Mark topology.topology_id_seq as a user data
    References #5344 in stable-3.2 branch (3.2.5dev)
diff --git a/NEWS b/NEWS
index 431828d5e..db467f09e 100644
--- a/NEWS
+++ b/NEWS
@@ -14,6 +14,7 @@ Proj 6.1+, and PostgreSQL 14+.
            enforce_coverage_tile_rast constraint (Regina Obe)
   - #5315, #5318, #5319, #5320, #5342 crashes on infinite coordinates
           (Regina Obe, Paul Ramsey)
+  - #5344, Include topology id sequence state in dumps (Sandro Santilli)
 PostGIS 3.2.4
 2022/11/12
diff --git a/extensions/postgis_topology/sql_bits/mark_editable_objects.sql.in b/extensions/postgis_topology/sql_bits/mark_editable_objects.sql.in
index ffc5c477f..b25e5b713 100644
--- a/extensions/postgis_topology/sql_bits/mark_editable_objects.sql.in
+++ b/extensions/postgis_topology/sql_bits/mark_editable_objects.sql.in
@@ -1,2 +1,3 @@
+SELECT pg_catalog.pg_extension_config_dump('topology.topology_id_seq', '');
 SELECT pg_catalog.pg_extension_config_dump('topology.topology', '');
 SELECT pg_catalog.pg_extension_config_dump('topology.layer', '');
Summary of changes:
 NEWS                                                              | 1 +
 extensions/postgis_topology/sql_bits/mark_editable_objects.sql.in | 1 +
 2 files changed, 2 insertions(+)
hooks/post-receive
