[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-644-g8de396392
Mon Feb 20 15:51:23 PST 2023
the project "PostGIS".
       via  8de396392c0e892c00e9cf04f8599c6e91d4c7e9 (commit)
       via  a1f513f0c467d7ebd6861f2b36c19d3cea5fc21b (commit)
      from  69e546bb5cd9a3d0c0e55d93163300a1bc4687f7 (commit)
revisions in full, below.
commit 8de396392c0e892c00e9cf04f8599c6e91d4c7e9
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Feb 21 00:50:55 2023 +0100
    run_test.pl: streamline name of tests being run (strip top-srcdir)
diff --git a/regress/run_test.pl b/regress/run_test.pl
index edbc7b56f..f1e883c93 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -49,7 +49,9 @@ BEGIN {
 our $DB = $ENV{"POSTGIS_REGRESS_DB"} || "postgis_reg";
 our $REGDIR = $ENV{"POSTGIS_REGRESS_DIR"} || abs_path(dirname($0));
-our $TOP_BUILDDIR = $ENV{"POSTGIS_TOP_BUILD_DIR"} || ${REGDIR} . '/..';
+our $TOP_SOURCEDIR = ${REGDIR} . '/..';
+our $ABS_TOP_SOURCEDIR = abs_path(${TOP_SOURCEDIR});
+our $TOP_BUILDDIR = $ENV{"POSTGIS_TOP_BUILD_DIR"} || ${TOP_SOURCEDIR};
 our $sysdiff = !system("diff --strip-trailing-cr $0 $0 2> /dev/null");
@@ -707,6 +709,12 @@ Options:
 sub start_test
     my $test = shift;
+    my $abstest = abs_path($test);
+    if ( defined($abstest) )
+        $test = $abstest;
+    $test =~ s|${ABS_TOP_SOURCEDIR}/||;
     print " $test ";
 	$RUN++;
     show_progress();
commit a1f513f0c467d7ebd6861f2b36c19d3cea5fc21b
Date:   Tue Feb 21 00:11:44 2023 +0100
    Skip restore of st_clusterkmeans(geom,int) comment
diff --git a/utils/postgis_restore.pl.in b/utils/postgis_restore.pl.in
index a61c33f37..e40043d3c 100644
--- a/utils/postgis_restore.pl.in
+++ b/utils/postgis_restore.pl.in
@@ -824,6 +824,7 @@ COMMENT FUNCTION st_clip(rast raster, nband integer[], geom geometry, nodataval
 COMMENT FUNCTION st_closestpoint(geom1 geometry, geom2 geometry)
 COMMENT FUNCTION st_closestpointofapproach(geometry, geometry)
 COMMENT FUNCTION st_clusterdbscan(geometry, eps double precision, minpoints integer)
+COMMENT FUNCTION st_clusterkmeans(geom geometry, k integer)
 COMMENT FUNCTION st_clusterkmeans(geom geometry, k integer, max_radius double precision)
 COMMENT FUNCTION st_collect(geom1 geometry, geom2 geometry)
 COMMENT FUNCTION st_collect(geometry[])
Summary of changes:
 regress/run_test.pl         | 10 +++++++++-
 utils/postgis_restore.pl.in |  1 +
 2 files changed, 10 insertions(+), 1 deletion(-)
hooks/post-receive
