[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-648-g87df5a875
Mon Feb 20 18:23:09 PST 2023
the project "PostGIS".
       via  87df5a875dcbc88fdeb84a85c0d9b2c648a71eae (commit)
       via  b0b44db3c95e0c73c1adaca97a5dddc8c36ff0c8 (commit)
       via  4505b2c17786db41b0e36da0fa0e90d05ba0bd8e (commit)
       via  ef8f92d99b7a5b086b3c365efc1d4e95951fb9b6 (commit)
      from  8de396392c0e892c00e9cf04f8599c6e91d4c7e9 (commit)
revisions in full, below.
commit 87df5a875dcbc88fdeb84a85c0d9b2c648a71eae
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Feb 21 03:21:24 2023 +0100
    run_test.pl: print where script-based upgrade is being done from
diff --git a/regress/run_test.pl b/regress/run_test.pl
index ab1b4f8ec..543eb7d64 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -1705,7 +1705,10 @@ sub package_extension_sql
 # Upgrade an existing database (soft upgrade)
 sub upgrade_spatial
-    print "Upgrading PostGIS in '${DB}' \n" ;
+    my $version = shift;
+    my $scriptdir = scriptdir($version);
+    print "Upgrading PostGIS in '${DB}' using scripts from $scriptdir\n" ;
     my $script = "${STAGED_SCRIPTS_DIR}/postgis_upgrade.sql";
     print "Upgrading core\n";
commit b0b44db3c95e0c73c1adaca97a5dddc8c36ff0c8
Date:   Tue Feb 21 03:11:21 2023 +0100
    Before upgrade hook of testsuite don't need to deal with dumprestore
    ... as it's always run AFTER dump and restore
diff --git a/regress/hooks/hook-before-upgrade.sql b/regress/hooks/hook-before-upgrade.sql
index 40287a78d..c156548a9 100644
--- a/regress/hooks/hook-before-upgrade.sql
+++ b/regress/hooks/hook-before-upgrade.sql
@@ -68,21 +68,7 @@ FROM upgrade_test;
 -- Break probin of all postgis functions, as we expect
 -- the upgrade procedure to replace them all
 UPDATE pg_proc SET probin = probin || '-uninstalled'
-WHERE probin like '%postgis%'
--- When testing dump/restore keep the type-output
--- function as they are needed for pg_dump
-AND (
-	:opt_dumprestore = 0 OR
-	oid NOT IN (
-		SELECT typoutput
-		FROM pg_type
-		WHERE typname IN ( 'geometry', 'geography', 'raster' )
-			UNION ALL
-		SELECT typmodout
-		FROM pg_type
+WHERE probin like '%postgis%';
 -- Change SECURITY of postgis_version() to DEFINER
commit 4505b2c17786db41b0e36da0fa0e90d05ba0bd8e
Date:   Tue Feb 21 03:10:06 2023 +0100
    run_test.pl: prepare restore db only if needed, add pre-dump and post-restore hooks
index ab0d7ea66..ab1b4f8ec 100755
@@ -79,6 +79,8 @@ my $OPT_WITH_SFCGAL = 0;
 my $OPT_EXPECT = 0;
 my $OPT_EXTENSIONS = 0;
 my @OPT_HOOK_AFTER_CREATE;
+my @OPT_HOOK_AFTER_RESTORE;
+my @OPT_HOOK_BEFORE_DUMP;
 my @OPT_HOOK_BEFORE_TEST;
 my @OPT_HOOK_AFTER_TEST;
 my @OPT_HOOK_BEFORE_UNINSTALL;
@@ -112,7 +114,9 @@ GetOptions (
 	'before-uninstall-script=s' => \@OPT_HOOK_BEFORE_UNINSTALL,
 	'before-test-script=s' => \@OPT_HOOK_BEFORE_TEST,
 	'before-upgrade-script=s' => \@OPT_HOOK_BEFORE_UPGRADE,
-	'after-upgrade-script=s' => \@OPT_HOOK_AFTER_UPGRADE
+	'before-dump-script=s' => \@OPT_HOOK_BEFORE_DUMP,
+	'after-upgrade-script=s' => \@OPT_HOOK_AFTER_UPGRADE,
+	'after-restore-script=s' => \@OPT_HOOK_AFTER_RESTORE
 if ( @ARGV < 1 )
@@ -686,6 +690,12 @@ Options:
   --before-uninstall-script <path>
                   script to load before spatial extension uninstall
                   (multiple switches supported, to be run in given order)
+  --before-dump-script <path>
+                  script to load before dump, if --dumprestore is given
+                  (multiple switches supported, to be run in given order)
+  --after-restore-script <path>
+                  script to load after restore, if --dumprestore is given
   --before-upgrade-script <path>
                   script to load before upgrade
@@ -2015,6 +2025,12 @@ sub dump_db
     my $rv;
     my $DBDUMP = $TMPDIR . '/' . $DB . '.dump';
+    foreach my $hook (@OPT_HOOK_BEFORE_DUMP)
+        print "Running before-dump-script $hook\n";
+        die unless load_sql_file($hook, 1);
     print "Dumping database '${DB}'\n";
     $rv = system("pg_dump -Fc -f${DBDUMP} ${DB} >> $REGRESS_LOG 2>&1");
@@ -2030,20 +2046,20 @@ sub restore_db
     my $rv;
     my $DBDUMP = shift;
+    my $ext_dump = $OPT_EXTENSIONS && $OPT_UPGRADE_FROM !~ /^unpackaged/;
-    # If the dump is NOT extension based
+    # If dump is not from extension-based database
     # we need to prepare the target
-    if ( $OPT_UPGRADE_FROM =~ /^unpackaged/ || ! $OPT_EXTENSIONS )
+    unless ( $ext_dump )
-        if ( $OPT_EXTENSIONS ) {
-            undef($OPT_UPGRADE_FROM); # to directly prepare the target
-            die unless prepare_spatial_extensions();
-        } else {
-            die unless prepare_spatial();
+		if ( $OPT_UPGRADE_FROM =~ /^unpackaged(.*)/ ) {
+			die unless prepare_spatial($1);
+		} else {
+			die unless prepare_spatial();
-    if ( $OPT_EXTENSIONS && ! $OPT_UPGRADE_FROM =~ /^unpackaged/ ) {
+    if ( $ext_dump ) {
         print "Restoring database '${DB}' using pg_restore\n";
         $rv = system("pg_restore -d ${DB} ${DBDUMP} >> $REGRESS_LOG 2>&1");
     } else {
@@ -2069,6 +2085,12 @@ sub restore_db
+    foreach my $hook (@OPT_HOOK_AFTER_RESTORE)
+        print "Running after-restore-script $hook\n";
     return 1;
commit ef8f92d99b7a5b086b3c365efc1d4e95951fb9b6
Date:   Tue Feb 21 01:49:19 2023 +0100
    run_test.pl: do not skip upgrade with --dumprestore and --upgrade
    Otherwise pre-upgrade scripts will break the functions and nothing
    would recover it
index f1e883c93..ab0d7ea66 100755
@@ -410,16 +410,13 @@ if ( $OPT_UPGRADE )
-    unless ( $OPT_DUMPRESTORE )
+    if ( $OPT_EXTENSIONS )
-            die unless upgrade_spatial_extensions();
-        else
-            die unless upgrade_spatial();
+        die unless upgrade_spatial_extensions();
+    else
+        die unless upgrade_spatial();
     foreach my $hook (@OPT_HOOK_AFTER_UPGRADE)
Summary of changes:
 regress/hooks/hook-before-upgrade.sql | 16 +---------
 regress/run_test.pl                   | 60 ++++++++++++++++++++++++-----------
 2 files changed, 42 insertions(+), 34 deletions(-)
hooks/post-receive
