[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-658-gc70c0762b
Tue Feb 21 15:33:42 PST 2023
the project "PostGIS".
       via  c70c0762b0b9210288a2b0a7f9caed50e3db9bd4 (commit)
       via  cf2b98cd0067bcb83ebebf06b9d46e0d79c921a5 (commit)
      from  a4c05cdefab572a3f54b1323cf392f0f837a804f (commit)
revisions in full, below.
commit c70c0762b0b9210288a2b0a7f9caed50e3db9bd4
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Feb 22 00:32:17 2023 +0100
    Simplify test, make easier to debug on failure
diff --git a/topology/test/regress/topoelement_cast.sql b/topology/test/regress/topoelement_cast.sql
index 727cac145..4460d53cc 100644
--- a/topology/test/regress/topoelement_cast.sql
+++ b/topology/test/regress/topoelement_cast.sql
@@ -13,33 +13,47 @@ SELECT NULL FROM AddTopoGeometryColumn('tt', 'tt', 'f_hier_point', 'g', 'POINT',
 -- populate base
 INSERT INTO tt.f_point(lbl,g)
-SELECT x::text||y::text, ToTopoGeom( ST_Point(x,y,4326), 'tt', l.layer_id )
-FROM generate_series(50,60, 10) AS x CROSS JOIN generate_series(10,90, 20) AS y
-    CROSS JOIN (SELECT l.layer_id
-                    FROM topology.layer AS l WHERE l.table_name = 'f_point' AND l.schema_name = 'tt' AND l.feature_column = 'g'
-               ) AS l;
+SELECT
+  x::text||y::text,
+  topology.toTopoGeom(
+    ST_Point(x,y,4326),
+    'tt',
+    layer_id(findLayer('tt','f_point', 'g'))
+FROM generate_series(50,60, 10) AS x
+CROSS JOIN generate_series(70,90, 20) AS y;
 -- populate hierarchy, cast
 INSERT INTO  tt.f_hier_point(lbl, g)
-SELECT left(f.lbl,2) AS lbl, CreateTopoGeom('tt',1, l.layer_id, TopoElementArray_agg(f.g::topology.topoelement ORDER BY f.lbl) )
-FROM  tt.f_point AS f CROSS JOIN
-    (SELECT l.layer_id FROM topology.layer AS l WHERE l.table_name = 'f_hier_point' AND l.schema_name = 'tt' AND l.feature_column = 'g' ) AS l
-GROUP BY l.layer_id, left(f.lbl,2);
-SELECT ST_AsText(g::geometry)
-FROM tt.f_hier_point;
+SELECT
+  format('bycast:%s', left(f.lbl,2)),
+  createTopoGeom(
+    'tt',
+    1,
+    layer_id(findLayer('tt','f_hier_point', 'g')),
+    TopoElementArray_agg( f.g::topology.topoelement ORDER BY f.lbl)
+FROM  tt.f_point AS f
+GROUP BY left(f.lbl,2);
 -- using FUNCTION
-SELECT 'all' AS lbl, CreateTopoGeom('tt',1, l.layer_id, TopoElementArray_agg(topology.topoelement(f.g) ORDER BY f.lbl) )
-GROUP BY l.layer_id;
-FROM tt.f_hier_point WHERE lbl = 'all';
+SELECT
+  format('byfunc:%s', right(f.lbl,2)),
+  createTopoGeom(
+    'tt',
+    1,
+GROUP BY right(f.lbl,2);
+SELECT 't1', lbl, ST_AsText(g::geometry)
+FROM tt.f_hier_point
+ORDER BY lbl;
 -- Cleanup
 SELECT NULL FROM DropTopology('tt');
diff --git a/topology/test/regress/topoelement_cast_expected b/topology/test/regress/topoelement_cast_expected
index edf63a426..1a3420f13 100644
--- a/topology/test/regress/topoelement_cast_expected
+++ b/topology/test/regress/topoelement_cast_expected
@@ -1,3 +1,4 @@
-MULTIPOINT((50 10),(50 30),(50 50),(50 70),(50 90))
-MULTIPOINT((60 10),(60 30),(60 50),(60 70),(60 90))
-MULTIPOINT((50 10),(50 30),(50 50),(50 70),(50 90),(60 10),(60 30),(60 50),(60 70),(60 90))
+t1|bycast:50|MULTIPOINT((50 70),(50 90))
+t1|bycast:60|MULTIPOINT((60 70),(60 90))
+t1|byfunc:70|MULTIPOINT((50 70),(60 70))
+t1|byfunc:90|MULTIPOINT((50 90),(60 90))
Summary of changes:
 doc/extras_topology.xml                         | 47 ++++++++++++++++++--
 topology/test/regress/topoelement_cast.sql      | 59 +++++++++++++++++++++++++
 topology/test/regress/topoelement_cast_expected |  4 ++
 topology/test/tests.mk                          |  3 +-
 topology/topology.sql.in                        | 25 +++++++++++
 5 files changed, 134 insertions(+), 4 deletions(-)
 create mode 100644 topology/test/regress/topoelement_cast.sql
 create mode 100644 topology/test/regress/topoelement_cast_expected
hooks/post-receive
