[postgis-tickets] [PostGIS] #5346: Unexpected left over files after distclean
PostGIS trac at osgeo.org
Tue Feb 21 16:11:23 PST 2023
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:  fixed                  |   Keywords:
Changes (by Sandro Santilli <strk@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"3d41b08dc006e9b838da9d449b40ee9af74b2ce6/git" 3d41b08/git]:
 {{{#!CommitTicketReference repository="git"
 revision="3d41b08dc006e9b838da9d449b40ee9af74b2ce6"
 Fix distlean
 - Run clean on loader's distclean
 - Do not generate extensions/upgrade-paths-rules.mk
 Move the hint about install-extension-upgrades-from-known-versions
 in top-level GNUMakefile
 Closes #5346
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5346#comment:1>
