[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-660-g3d41b08dc
Tue Feb 21 16:11:17 PST 2023
the project "PostGIS".
       via  3d41b08dc006e9b838da9d449b40ee9af74b2ce6 (commit)
      from  83e7f6cd7e6de93c785b540ccb6da8a45537955a (commit)
revisions in full, below.
commit 3d41b08dc006e9b838da9d449b40ee9af74b2ce6
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Feb 22 00:42:23 2023 +0100
    Fix distlean
    - Run clean on loader's distclean
    - Do not generate extensions/upgrade-paths-rules.mk
    Move the hint about install-extension-upgrades-from-known-versions
    in top-level GNUMakefile
    Closes #5346
diff --git a/.gitignore b/.gitignore
index 2a8570a43..8485dcc10 100644
--- a/.gitignore
+++ b/.gitignore
@@ -44,7 +44,6 @@ doc/raster_gardentest_*.sql
 doc/tiger_geocoder_comments.sql
 doc/topology_comments.sql
 extensions/Makefile
-extensions/upgrade-paths-rules.mk
 extensions/address_standardizer/Makefile
 extensions/address_standardizer/mk-st-regexp
 extensions/address_standardizer/address_standardizer--*.sql
diff --git a/GNUmakefile.in b/GNUmakefile.in
index 8c265bc4f..17d43cc60 100644
--- a/GNUmakefile.in
+++ b/GNUmakefile.in
@@ -29,8 +29,10 @@ all install uninstall noop clean distclean check-unit:
 	@if test x"$@" = xall; then \
 		echo "PostGIS was built successfully. Ready to install."; \
 	fi
-ifneq (@INSTALL_EXTENSION_UPGRADES@,yes)
 ifneq (@EXTENSIONS@,)
+ifeq (@INSTALL_EXTENSION_UPGRADES@, yes)
+	$(MAKE) install-extension-upgrades-from-known-versions
+else
 	@if test x"$@" = xinstall; then \
 		echo; \
 		echo "PostGIS extensions installed, upgrade scripts retained."; \
diff --git a/configure.ac b/configure.ac
index 80cd6c8dc..e4cd41603 100644
--- a/configure.ac
+++ b/configure.ac
@@ -1738,7 +1738,6 @@ dnl echo "TRANSLATIONS_MAKEFILE_LIST: ${TRANSLATIONS_MAKEFILE_LIST}"
 AC_CONFIG_FILES([GNUmakefile
    extensions/Makefile
-   extensions/upgrade-paths-rules.mk
    extensions/postgis/Makefile
    extensions/postgis_topology/Makefile
    extensions/postgis_tiger_geocoder/Makefile
diff --git a/extensions/address_standardizer/Makefile.in b/extensions/address_standardizer/Makefile.in
index 5fac487c5..cbf35ae28 100644
--- a/extensions/address_standardizer/Makefile.in
+++ b/extensions/address_standardizer/Makefile.in
@@ -119,7 +119,7 @@ sql/$(EXTENSION)--ANY--$(EXTVERSION).sql: $(EXTENSION_UPGRADE_SCRIPTS)
 sql/$(EXTENSION)_data_us--ANY--$(EXTVERSION).sql: sql/$(EXTENSION)_data_us--$(EXTVERSION).sql | sql
 	cat $^ > $@
-include ../upgrade-paths-rules.mk
+include @srcdir@/../upgrade-paths-rules.mk
 # TODO: fix this by moving data in their own directories
 ifeq ($(EXTENSION_DATA_INSTALL),)
diff --git a/extensions/postgis/Makefile.in b/extensions/postgis/Makefile.in
index 4cd1bdcb2..1d5619bc4 100644
--- a/extensions/postgis/Makefile.in
+++ b/extensions/postgis/Makefile.in
@@ -140,7 +140,7 @@ sql/$(EXTENSION)--ANY--$(EXTVERSION).sql: $(EXTENSION_UPGRADE_SCRIPTS) | sql
 	printf '\\echo Use "CREATE EXTENSION $(EXTENSION)" to load this file. \\quit\n' > $@
 	cat $^ >> $@
 distclean: clean
 	rm -f Makefile
diff --git a/extensions/postgis_raster/Makefile.in b/extensions/postgis_raster/Makefile.in
index bb78d7a23..1d061f114 100644
--- a/extensions/postgis_raster/Makefile.in
+++ b/extensions/postgis_raster/Makefile.in
@@ -122,7 +122,7 @@ sql/$(EXTENSION)--ANY--$(EXTVERSION).sql: $(EXTENSION_UPGRADE_SCRIPTS) | sql
 	cat $^ >> $@
 distclean: clean
 	rm -f Makefile
diff --git a/extensions/postgis_sfcgal/Makefile.in b/extensions/postgis_sfcgal/Makefile.in
index 73f828b5b..6acb88a6b 100644
--- a/extensions/postgis_sfcgal/Makefile.in
+++ b/extensions/postgis_sfcgal/Makefile.in
@@ -94,7 +94,7 @@ sql/sfcgal_upgrade_minor.sql: ../postgis_extension_helper.sql sql/sfcgal_upgrade
 	cat $(EXTENSION_UPGRADE_SCRIPTS) > $@
 distclean: clean
 	rm Makefile
diff --git a/extensions/postgis_tiger_geocoder/Makefile.in b/extensions/postgis_tiger_geocoder/Makefile.in
index de3d37f57..8c7df1532 100644
--- a/extensions/postgis_tiger_geocoder/Makefile.in
+++ b/extensions/postgis_tiger_geocoder/Makefile.in
@@ -205,7 +205,7 @@ sql/tiger_geocoder_upgrade_minor.sql:  sql/tiger_geocoder_minor.sql.in | sql
 #only extension files
 EXTRA_CLEAN += $(wildcard expected/*--*.out)
 distclean: clean
 	rm Makefile
diff --git a/extensions/postgis_topology/Makefile.in b/extensions/postgis_topology/Makefile.in
index 763fdb5ac..e63f8f3d1 100644
--- a/extensions/postgis_topology/Makefile.in
+++ b/extensions/postgis_topology/Makefile.in
@@ -99,7 +99,7 @@ sql/topology_upgrade.sql:  ../../topology/topology_upgrade.sql | sql
 	cat $^ > $@
 distclean: clean
 	rm Makefile
diff --git a/extensions/upgrade-paths-rules.mk.in b/extensions/upgrade-paths-rules.mk
similarity index 93%
rename from extensions/upgrade-paths-rules.mk.in
rename to extensions/upgrade-paths-rules.mk
index 6759dd32a..b82d7c68f 100644
--- a/extensions/upgrade-paths-rules.mk.in
+++ b/extensions/upgrade-paths-rules.mk
@@ -23,9 +23,6 @@ install-upgrade-paths: tag-as-any
 	$(INSTALL_DATA) sql/$${tpl} "$(EXTDIR)/$${tpl}"; \
 	$(INSTALL_DATA) "sql/$(TAG_UPGRADE)" "$(EXTDIR)/$(TAG_UPGRADE)"; \
 	ln -fs "$(TAG_UPGRADE)" $(EXTDIR)/$(EXTENSION)--$(EXTVERSION)--ANY.sql;
-ifeq (@INSTALL_EXTENSION_UPGRADES@,yes)
-	$(MAKE) install-extension-upgrades-from-known-versions
-endif
 install-extension-upgrades-from-known-versions:
 	$(PERL) $(top_srcdir)/loader/postgis.pl \
diff --git a/loader/Makefile.in b/loader/Makefile.in
index 7db7c82f8..06dd74e1b 100644
--- a/loader/Makefile.in
+++ b/loader/Makefile.in
@@ -177,7 +177,7 @@ clean:
 	rm -f *.o $(SHP2PGSQL-CLI) $(PGSQL2SHP-CLI) $(GTK_WIN32_RES) $(SHP2PGSQL-GUI) $(POSTGIS-CLI)
 	$(MAKE) -C cunit clean
-distclean:
+distclean: clean
 	$(MAKE) -C cunit distclean
 	rm -f Makefile
Summary of changes:
 .gitignore                                                       | 1 -
 GNUmakefile.in                                                   | 4 +++-
 configure.ac                                                     | 1 -
 extensions/address_standardizer/Makefile.in                      | 2 +-
 extensions/postgis/Makefile.in                                   | 2 +-
 extensions/postgis_raster/Makefile.in                            | 2 +-
 extensions/postgis_sfcgal/Makefile.in                            | 2 +-
 extensions/postgis_tiger_geocoder/Makefile.in                    | 2 +-
 extensions/postgis_topology/Makefile.in                          | 2 +-
 extensions/{upgrade-paths-rules.mk.in => upgrade-paths-rules.mk} | 3 ---
 loader/Makefile.in                                               | 2 +-
 11 files changed, 10 insertions(+), 13 deletions(-)
 rename extensions/{upgrade-paths-rules.mk.in => upgrade-paths-rules.mk} (93%)
hooks/post-receive
