[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-662-g34b58d2bf
Tue Feb 21 17:05:35 PST 2023
the project "PostGIS".
       via  34b58d2bf4c4d8aaeb482a68942b5fcad8ea260b (commit)
       via  017ea53a6394bdfee1e20c3ed98755c922a4f991 (commit)
      from  3d41b08dc006e9b838da9d449b40ee9af74b2ce6 (commit)
revisions in full, below.
commit 34b58d2bf4c4d8aaeb482a68942b5fcad8ea260b
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Feb 22 02:05:35 2023 +0100
    Hint about installing missing upgrade scripts
diff --git a/utils/check_all_upgrades.sh b/utils/check_all_upgrades.sh
index c16436546..9c3779bf7 100755
--- a/utils/check_all_upgrades.sh
+++ b/utils/check_all_upgrades.sh
@@ -33,10 +33,11 @@ fi
 mkdir -p ${TMPDIR}
 cleanup()
+  echo "Cleaning up"
   rm -rf ${TMPDIR}
-trap 'cleanup' 0
+trap 'cleanup' EXIT
 # Return -1, 1 or 0 if the first version
@@ -71,7 +72,7 @@ semver_compare()
 failed()
   failures=$((failures+1))
-  if test $EXIT_ON_FIRST_FAILURE != 0 -a $failures != 0; then
+  if test $EXIT_ON_FIRST_FAILURE != 0; then
     exit $failures
   fi
@@ -129,10 +130,22 @@ compatible_upgrade()
   return 0
+report_missing_versions()
+  if test -n "${MISSING_EXT_UPGRADES}"; then
+    echo "INFO: missing upgrade scripts: ${MISSING_EXT_UPGRADES}"
+    echo "HINT: use 'postgis install-extension-upgrades' to install them"
+  fi
+  cleanup
 to_version_param="$1"
 to_version=$to_version_param
 if expr $to_version : ':auto' >/dev/null; then
   to_version=`psql -XAtc "select default_version from pg_available_extensions where name = 'postgis'"` || exit 1
+  MISSING_EXT_UPGRADES=
+  trap report_missing_versions EXIT
 elif expr $to_version : '.*!$' >/dev/null; then
   to_version=$(echo "${to_version}" | sed 's/\!$//')
 fi
@@ -188,6 +201,7 @@ for EXT in ${INSTALLED_EXTENSIONS}; do
     " ) || exit 1
     if test -z "${path}"; then
       echo "SKIP: ${test_label} (no upgrade path from ${from_version} to ${to_version} known by postgresql)"
+      MISSING_EXT_UPGRADES="${from_version} ${MISSING_EXT_UPGRADES}"
       continue
     fi
     echo "Testing ${test_label}"
commit 017ea53a6394bdfee1e20c3ed98755c922a4f991
Date:   Wed Feb 22 02:01:14 2023 +0100
    Fix bogus install of extension upgrade paths at the wrong time
diff --git a/GNUmakefile.in b/GNUmakefile.in
index 17d43cc60..93954d75b 100644
--- a/GNUmakefile.in
+++ b/GNUmakefile.in
@@ -31,7 +31,9 @@ all install uninstall noop clean distclean check-unit:
 	fi
 ifneq (@EXTENSIONS@,)
 ifeq (@INSTALL_EXTENSION_UPGRADES@, yes)
-	$(MAKE) install-extension-upgrades-from-known-versions
+	@if test x"$@" = xinstall; then \
+		$(MAKE) install-extension-upgrades-from-known-versions; \
+	fi
 else
 		echo; \
Summary of changes:
 GNUmakefile.in              |  4 +++-
 utils/check_all_upgrades.sh | 18 ++++++++++++++++--
 2 files changed, 19 insertions(+), 3 deletions(-)
hooks/post-receive
