[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-663-ge310da6fb
Tue Feb 21 17:12:09 PST 2023
the project "PostGIS".
       via  e310da6fb07ed8d97660312ad6612f889f190ff0 (commit)
      from  34b58d2bf4c4d8aaeb482a68942b5fcad8ea260b (commit)
revisions in full, below.
commit e310da6fb07ed8d97660312ad6612f889f190ff0
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Feb 22 02:11:51 2023 +0100
    Simplify the install hook
diff --git a/GNUmakefile.in b/GNUmakefile.in
index 93954d75b..2f9ac0530 100644
--- a/GNUmakefile.in
+++ b/GNUmakefile.in
@@ -30,22 +30,20 @@ all install uninstall noop clean distclean check-unit:
 		echo "PostGIS was built successfully. Ready to install."; \
 	fi
 ifneq (@EXTENSIONS@,)
-ifeq (@INSTALL_EXTENSION_UPGRADES@, yes)
 	@if test x"$@" = xinstall; then \
-		$(MAKE) install-extension-upgrades-from-known-versions; \
+		if test x"@INSTALL_EXTENSION_UPGRADES@" = xyes; then \
+			$(MAKE) install-extension-upgrades-from-known-versions; \
+		else \
+			echo; \
+			echo "PostGIS extensions installed, upgrade scripts retained."; \
+			echo; \
+			echo "You may use the "postgis" script to only install the ones you need, or";\
+			echo "you can install the ones required to upgrade from currently known versions with:"; \
+			echo; \
+			echo "  make install-extension-upgrades-from-known-versions"; \
+			echo; \
+		fi; \
 	fi
-else
-	@if test x"$@" = xinstall; then \
-		echo; \
-		echo "PostGIS extensions installed, upgrade scripts retained."; \
-		echo; \
-		echo "You may use the "postgis" script to only install the ones you need, or";\
-		echo "you can install the ones required to upgrade from currently known versions with:"; \
-		echo; \
-		echo "  make install-extension-upgrades-from-known-versions"; \
-		echo; \
-	fi
-endif
 endif
Summary of changes:
 GNUmakefile.in | 26 ++++++++++++--------------
 1 file changed, 12 insertions(+), 14 deletions(-)
hooks/post-receive
