[postgis-tickets] [PostGIS] #5348: Non-extension based dump-restore tests failing on new ST_ClusterIntersectingWin
PostGIS trac at osgeo.org
Sun Feb 26 20:43:04 PST 2023
 Reporter:  robe                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  medium                 |  Milestone:  PostGIS 3.4.0
Component:  build/upgrade/install  |    Version:  master
 Keywords:                         |
 The new functions on https://github.com/postgis/postgis/pull/721
 are triggering failure
 when running
 make check RUNTESTFLAGS="-v --dumprestore"
 errors with:
 ERROR:  function "st_clusterintersectingwin" already exists with same
 argument types
 So I presume postgis_restore.pl is not filtering this function out for
 some reason.
 But work fine with
 make check RUNTESTFLAGS="-v --extension--dumprestore"
 I'm not seeing anything wrong with the availability checks in it.
 I thought maybe postgis_restore.pl is not handling window functions, but
 if that is the case it should have chocked also on ST_ClusterDBScan and
 ST_ClusterKMeans.
 Whatever the issue is I figure we can fix after its commited.
 I'm changing cirrus to test against extension based install, which I think
 is more useful too  because all fixes that would be done using schema
 quals I assume will only be fixed in extension based dump/restore
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5348>
