[postgis-tickets] [PostGIS] #5348: Non-extension based dump-restore tests failing on new ST_ClusterIntersectingWin
PostGIS trac at osgeo.org
Sun Feb 26 20:44:21 PST 2023
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by Regina Obe <lr@…>):
 In [changeset:"9ea9b67580a3c0a5b562f1cd0922efba264e747a/git"
 9ea9b675/git]:
 {{{#!CommitTicketReference repository="git"
 revision="9ea9b67580a3c0a5b562f1cd0922efba264e747a"
 Change Cirrus to do extension based dumprestore
 Was doing script installed dumprestore check
 which causes a failure in https://github.com/postgis/postgis/pull/721
 Dumprestore Issue references #5348
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5348#comment:1>
