[postgis-tickets] [PostGIS] #5348: Non-extension based dump-restore tests failing on new ST_ClusterIntersectingWin
PostGIS trac at osgeo.org
Mon Feb 27 01:20:17 PST 2023
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by strk):
 When non-extension dumprestore fails it's probably the postgis_restore.pl
 script missing knowledge about a signature that should be stripped from
 the dump. It might be useful to generate part of that list, given our
 source knows about ANY signature we EVER released in a version we support
 soft-upgrade from, but those dumps could also come from earlier version,
 which is why the list we can generate is partial.
 I'm pretty sure restoring a dump from very early releases is going to
 error out, btw, as we never had a bot testing those ancient dump restores
 (and current run_test.pl does not support testing restore-only either).
 Anyway, for this ticket, check out how the signature is missing here:
 https://trac.osgeo.org/postgis/browser/git/utils/postgis_restore.pl.in#L1961
 Remember to also add the COMMENT part
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5348#comment:2>
