[postgis-tickets] [PostGIS] #5348: Non-extension based dump-restore tests failing on new ST_ClusterIntersectingWin
PostGIS trac at osgeo.org
Mon Feb 27 09:22:32 PST 2023
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  assigned
  Priority:  medium                 |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Changes (by strk):
 * status:  new => assigned
Comment:
 I just realized we are theoretically ALREADY generating the list of
 signatures to strip, via the `update-restore` Makefile rule under
 utils/Makefile.in -- I will check to see why that one is failing and
 whether I broke it at some point
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5348#comment:3>
