[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-678-g8f0c476ef
Tue Feb 28 18:01:33 PST 2023
the project "PostGIS".
       via  8f0c476ef71748e3f6ff7fe29d86b652d23c7f75 (commit)
      from  02738b2d252a7910bd84b04459bd12d6504af698 (commit)
revisions in full, below.
commit 8f0c476ef71748e3f6ff7fe29d86b652d23c7f75
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Mar 1 03:01:35 2023 +0100
    Generate aggregate items of skip list
diff --git a/utils/create_skip_signatures.pl b/utils/create_skip_signatures.pl
index 9aa8f7d82..01492d742 100644
--- a/utils/create_skip_signatures.pl
+++ b/utils/create_skip_signatures.pl
@@ -62,6 +62,24 @@ sub strip_argument_names {
 	return @out;
+sub canonicalize_args {
+	my @args = @_;
+	my @out;
+	foreach ( @args )
+		my $a = $_;
+		$a =~ s/varchar/character varying/g;
+		$a =~ s/float8/double precision/g;
+		$a =~ s/\bint\b/integer/g;
+		$a =~ s/\bint4\b/integer/g;
+		$a =~ s/\bint8\b/bigint/g;
+		$a =~ s/\bchar\b/character/g;
+		$a =~ s/\bbool\b/boolean/g;
+		push @out, $a;
+	return @out;
 while (<>)
 	#print "XXX 0 $_";
@@ -75,6 +93,28 @@ while (<>)
 		print "TYPE $t\n";
+	# aggregate signature
+	if ( /^DROP AGGREGATE IF EXISTS\s+(.*)\((.*)\)/ )
+		my $name = lc($1);
+		my $args = lc($2);
+		s/^\s+//, s/\s+$// for $name;
+		$name =~ s/topology\.//g;
+		$args =~ s/topology\.//g;
+		my @args = split('\s*,\s*', $args);
+		@args = canonicalize_args(@args);
+		print "COMMENT AGGREGATE $name(" . join(', ', @args) . ")\n";
+		# For *aggregate* signature we are supposed to strip
+		# also argument names, which aint easy
+		my @unnamed_args = strip_argument_names(@args);
+		print "AGGREGATE $name(" . join(', ', @unnamed_args) . ")\n";
 	# Function signature
 	elsif ( /^DROP FUNCTION IF EXISTS/ )
@@ -90,21 +130,14 @@ while (<>)
 		$line = lc($line);
 		$line =~ s/topology\.//g;
-		$line =~ s/varchar/character varying/g;
-		$line =~ s/float8/double precision/g;
-		$line =~ s/\bint\b/integer/g;
-		$line =~ s/\bint4\b/integer/g;
-		$line =~ s/\bint8\b/bigint/g;
-		$line =~ s/\bchar\b/character/g;
 		$line =~ m/ *([^\( ]*) *\((.*)\)/ or die "Unexpected DROP FUNCTION syntax: $origline";
 		my $name = lc($1);
 		my $args = lc($2);
-		s/^\s+//, s/\s+$// for $args;
-		#$args =~ s/\s*,\s*/,/g;
 		print "COMMENT FUNCTION $name(" . join(', ', @args) .")\n";
diff --git a/utils/postgis_restore.pl.in b/utils/postgis_restore.pl.in
index fe797a324..cef63213e 100644
--- a/utils/postgis_restore.pl.in
+++ b/utils/postgis_restore.pl.in
@@ -499,41 +499,6 @@ ACL TABLE raster_columns
 ACL TABLE raster_overviews
 ACL TABLE spatial_ref_sys
 ACL TABLE topology
-AGGREGATE st_3dextent(geometry)
-AGGREGATE st_3dunion(geometry)
-AGGREGATE st_asflatgeobuf(anyelement)
-AGGREGATE st_asflatgeobuf(anyelement, boolean)
-AGGREGATE st_asflatgeobuf(anyelement, boolean, text)
-AGGREGATE st_asgeobuf(anyelement)
-AGGREGATE st_asgeobuf(anyelement, text)
-AGGREGATE st_asmvt(anyelement)
-AGGREGATE st_asmvt(anyelement, text)
-AGGREGATE st_asmvt(anyelement, text, integer)
-AGGREGATE st_asmvt(anyelement, text, integer, text)
-AGGREGATE st_asmvt(anyelement, text, integer, text, text)
-AGGREGATE st_clusterintersecting(geometry)
-AGGREGATE st_clusterwithin(geometry, double precision)
-AGGREGATE st_collect(geometry)
-AGGREGATE st_countagg(raster, boolean)
-AGGREGATE st_countagg(raster, integer, boolean)
-AGGREGATE st_countagg(raster, integer, boolean, double precision)
-AGGREGATE st_extent(geometry)
-AGGREGATE st_makeline(geometry)
-AGGREGATE st_memcollect(geometry)
-AGGREGATE st_memunion(geometry)
-AGGREGATE st_polygonize(geometry)
-AGGREGATE st_samealignment(raster)
-AGGREGATE st_summarystatsagg(raster, boolean, double precision)
-AGGREGATE st_summarystatsagg(raster, integer, boolean)
-AGGREGATE st_summarystatsagg(raster, integer, boolean, double precision)
-AGGREGATE st_union(geometry)
-AGGREGATE st_union(geometry, double precision)
-AGGREGATE st_union(raster)
-AGGREGATE st_union(raster, integer)
-AGGREGATE st_union(raster, integer, text)
-AGGREGATE st_union(raster, text)
-AGGREGATE st_union(raster, unionarg[])
-AGGREGATE topoelementarray_agg(topoelement)
 CAST (box2d AS box3d)
 CAST (box2d AS geometry)
 CAST (box3d AS box)
@@ -591,30 +556,6 @@ CAST (path AS geometry)
 CAST (point AS geometry)
 CAST (polygon AS geometry)
 CAST (text AS geometry)
-COMMENT AGGREGATE st_3dextent(geometry)
-COMMENT AGGREGATE st_3dunion(geometry)
-COMMENT AGGREGATE st_clusterintersecting(geometry)
-COMMENT AGGREGATE st_clusterwithin(geometry, double precision)
-COMMENT AGGREGATE st_collect(geometry)
-COMMENT AGGREGATE st_countagg(raster, boolean)
-COMMENT AGGREGATE st_countagg(raster, integer, boolean)
-COMMENT AGGREGATE st_countagg(raster, integer, boolean, double precision)
-COMMENT AGGREGATE st_extent(geometry)
-COMMENT AGGREGATE st_makeline(geometry)
-COMMENT AGGREGATE st_memunion(geometry)
-COMMENT AGGREGATE st_polygonize(geometry)
-COMMENT AGGREGATE st_samealignment(raster)
-COMMENT AGGREGATE st_summarystatsagg(raster, boolean, double precision)
-COMMENT AGGREGATE st_summarystatsagg(raster, integer, boolean)
-COMMENT AGGREGATE st_summarystatsagg(raster, integer, boolean, double precision)
-COMMENT AGGREGATE st_union(geometry)
-COMMENT AGGREGATE st_union(geometry, gridsize double precision)
-COMMENT AGGREGATE st_union(raster)
-COMMENT AGGREGATE st_union(raster, integer)
-COMMENT AGGREGATE st_union(raster, integer, text)
-COMMENT AGGREGATE st_union(raster, text)
-COMMENT AGGREGATE st_union(raster, unionarg[])
-COMMENT AGGREGATE topoelementarray_agg(topoelement)
 COMMENT DOMAIN topoelement
 COMMENT DOMAIN topoelementarray
 COMMENT FUNCTION addrasterconstraints(rastschema name, rasttable name, rastcolumn name, VARIADIC constraints text[])
@@ -702,8 +643,6 @@ FUNCTION json(geometry)
 FUNCTION lockrow(text, text, text, text, timestamp without time zone)
 FUNCTION lockrow(text, text, text, timestamp without time zone)
 FUNCTION _overview_constraint_info(name, name, name)
-FUNCTION pgis_asflatgeobuf_transfn(internal, anyelement, boolean)
-FUNCTION pgis_asflatgeobuf_transfn(internal, anyelement, boolean, text)
 FUNCTION postgis_extensions_upgrade()
 FUNCTION st_asgeojson(record, text, integer, boolean)
 FUNCTION st_asmvtgeom(geometry, box2d, integer, integer, boolean)
Summary of changes:
 utils/create_skip_signatures.pl | 51 ++++++++++++++++++++++++++++------
 utils/postgis_restore.pl.in     | 61 -----------------------------------------
 2 files changed, 42 insertions(+), 70 deletions(-)
hooks/post-receive
