[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-679-g05c8c7f4d
Tue Feb 28 20:32:34 PST 2023
the project "PostGIS".
       via  05c8c7f4de05b9c7388a01f7d853b65129f77a71 (commit)
      from  8f0c476ef71748e3f6ff7fe29d86b652d23c7f75 (commit)
revisions in full, below.
commit 05c8c7f4de05b9c7388a01f7d853b65129f77a71
Author: Regina Obe <lr at pcorp.us>
Date:   Tue Feb 28 23:27:47 2023 -0500
    Add GEOMETRYCOLLECTION (POINT EMPTY, LINESTRING (0 0, 1 1))
    to postgis garden test, but leave out ST_AsSVG
    until #5350 is addressed
diff --git a/doc/xsl/postgis_gardentest.sql.xsl b/doc/xsl/postgis_gardentest.sql.xsl
index 36bae0635..0f14d1dbe 100644
--- a/doc/xsl/postgis_gardentest.sql.xsl
+++ b/doc/xsl/postgis_gardentest.sql.xsl
@@ -10,7 +10,7 @@
 	<xsl:output method="text" />
 	<xsl:variable name='testversion'>3.4.0</xsl:variable>
 	<xsl:variable name='fnexclude14'>AddGeometryColumn DropGeometryColumn DropGeometryTable</xsl:variable>
-	<xsl:variable name='fnexclude'>AddGeometryColumn DropGeometryColumn DropGeometryTable</xsl:variable>
+	<xsl:variable name='fnexclude'>AddGeometryColumn DropGeometryColumn DropGeometryTable ST_AsSVG</xsl:variable>
 	<!--This is just a place holder to state functions not supported or tested separately -->
 	<xsl:variable name='var_srid'>3395</xsl:variable>
@@ -258,6 +258,12 @@ FROM (VALUES ( ST_GeomFromEWKT('SRID=4326;MULTIPOLYGON(((-71.0821 42.3036 2,-71.
 		 (SELECT ST_GeomFromText('GEOMETRYCOLLECTION EMPTY',4326) As the_geom )
 		</pgis:gset>
+		<pgis:gset ID="Geometry Collection with Empty Point" GeometryType="GEOMETRY" createtable="false">
+		 (SELECT ST_GeomFromText('GEOMETRYCOLLECTION (POINT EMPTY, LINESTRING (0 0, 1 1))',4326) As the_geom )
+		</pgis:gset>
 		<pgis:gset ID="Single NULL" GeometryType="GEOMETRY" createtable="false">(SELECT CAST(Null As geometry) As the_geom)</pgis:gset>
 		<pgis:gset ID="Multiple NULLs" GeometryType="GEOMETRY" createtable="false">(SELECT CAST(Null As geometry) As the_geom FROM generate_series(1,4) As foo)</pgis:gset>
Summary of changes:
 doc/xsl/postgis_gardentest.sql.xsl | 8 +++++++-
 1 file changed, 7 insertions(+), 1 deletion(-)
hooks/post-receive
