[postgis-tickets] [PostGIS] #5309: ST_ClusterKMeans not working on PostGIS 3.23
PostGIS trac at osgeo.org
Sat Jan 7 03:53:39 PST 2023
  Reporter:  jbtw        |      Owner:  pramsey
      Type:  defect      |     Status:  closed
  Priority:  medium      |  Milestone:
 Component:  postgis     |    Version:  3.2.x
Resolution:  worksforme  |   Keywords:
Changes (by komzpa):
 * status:  new => closed
 * resolution:   => worksforme
Comment:
 Hello,
 I cannot reproduce this on my PostGIS 3.3.2. Your PostGIS full version
 output suggests there is a problem with how you upgraded the system,
 mixing up 3.2.3, 2.4.3, and 3.1.4 at the same time. Please run SELECT
 postgis_extensions_upgrade(); in all of your databases and try again,
 until postgis_full_version() does not show the discrepancy of core procs
 version and the library version. Also consider upgrading to the 3.3
 branch. If problem persists, please reopen this ticket with new details.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5309#comment:1>
